6" backspacing too much?
Old Mar 1, 2007 | 03:30 PM
strumm's Avatar
strumm
Was just curious if anyone knew if a wheel with 6" bs would fit without any issues on the new f-150 with only the autospring level kit.
Old Mar 2, 2007 | 12:50 AM
Wakeboarder141's Avatar
Wakeboarder141
I am also curious about which backspacing/offset is required on these trucks. I have heard mixed things about what will work, and am more confused than when I started shopping.
Old Mar 2, 2007 | 12:53 AM
countryboy851's Avatar
countryboy851
why so much backspacing?
Old Mar 2, 2007 | 01:17 AM
strumm's Avatar
strumm
I'm told the bs on the factory wheels is 5.5 inches. The wheel im looking at is a moto metal 950 18x9 and comes in 2 offsets 4.5 or 6. If I figure right (and please tell me if im wrong) with the 4.5 bs my wheels will stick out 2.5" farther than stock, and with the 6" bs only 1" farther. I just want to keep as much of my tires in the fender wheel as possible.
Old Mar 2, 2007 | 01:25 AM
Wakeboarder141
I was looking at the Moto Metal 951, which is a 4.5" BS and -12mm offset, which I am assuming would make the wheel stick out further, although it is listed on some websites as fitting my truck, I'm not so sure.
Old Mar 2, 2007 | 04:25 PM
countryboy851
i have a set of weld cheyanne 6's on my truck with 4.5" backspace and *6mm offset. sticks out about 2.5 inches but doesnt look bad, i just guess it depends on what tires your'e going to run on them. i have 33x12.50 on 17's and they look great in my opinion anyways. i'll try to post some pictures in the next week so you can see what it looks like.
Old Mar 2, 2007 | 05:34 PM
Wakeboarder141
I would be running 33x12.50x17 also. What width are your wheels? Was that -6mm or +6mm offset? If yours are +6mm, I would think -12mm would make it stick out a ton more. Thanks.
Old Mar 3, 2007 | 01:08 AM
countryboy851
sorry. the wheels are 17x8.5, -6mm offset 4.5" backspace
Old Mar 3, 2007 | 12:17 PM
Wakeboarder141
Ok, so with a 9" wide wheel and -12mm of offset that is probably close to the same setup. Please post some pics so I can see how far that sticks out. Thanks.
Old Mar 3, 2007 | 10:09 PM
adbarron's Avatar
adbarron
Visit this web page. It will give you the answers you need.
http://www.rims-n-tires.com/rt_specs.jsp
Put in your OEM specs and the new ones. It will tell what you need to know.
Old Mar 4, 2007 | 02:05 AM
Wakeboarder141
The only problem is, without taking my wheel off I am not sure what the OEM wheel specs are. According to that website, anything lower than +25mm offset is too low on my truck, but I know there are people running lower offset than that.
Old Mar 4, 2007 | 04:14 AM
adbarron's Avatar
adbarron
I am running BFG 305/65/18's with MB Motoring Razor wheels. +25mm offset with 5.7" back space. I have no rub at all and they stick out about 1 inch further than OEM.
adbarron's Avatar
adbarron
Old Mar 4, 2007 | 11:53 PM
strumm's Avatar
strumm
Thanks adbarron exactly what I wanted to hear. Any chance of some pics?
Old Mar 17, 2007 | 04:12 PM
adbarron's Avatar
adbarron
Finally have some pics
sabre737
1978 - 1996 Big Bronco
Oct 27, 2001 07:59 PM
hpguy
Jun 3, 2001 07:47 AM
karljay
Mar 20, 2001 10:51 AM
hpguy
Jan 19, 2001 10:19 AM
rogwelch
Feb 12, 2000 11:29 PM
