Replaceing carrier bearing
Old Mar 1, 2007 | 12:46 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
How hard is it to replace the carrier bearing on a crew cab F350?
I crawled under the truck this morning and noticed it was a little worn.
When I grabed it, it moved around quite abit so I am assuming that it needs replaced. I checked all the u joints and they are good. How does the bearing come off?
Old Mar 1, 2007 | 12:50 AM
fishmanndotcom's Avatar
fishmanndotcom
its not bad, but it does need to be pressed off and the new one pressed back on
-cutts-
Old Mar 1, 2007 | 10:21 AM
Stroker 94 1/2
Thanks fishman. How does the drive shaft come apart? I have always had a single drive shaft so this is new to me.
Old Mar 1, 2007 | 12:49 PM
tjbeggs's Avatar
tjbeggs
the back half of the shaft just slides off after you cut the clamps on the rubber boot. I usually cut the bearing off with a torch and sometimes you can use an air hammer to get it off. the torch is easy if you are good with it. if you are no you can cut too much and harm the shaft.
Old Mar 7, 2007 | 02:53 PM
Stroker 94 1/2
Thanks guys finally got the bearing replaced. I needed to take it and have it pulled and pressed back on like you guys said. Thanks for the help again!!
351Cleveland C4
Aug 11, 2014 02:44 PM
rockittsled
May 17, 2014 08:08 PM
powerstroker100
Nov 1, 2011 08:04 PM
84-250
Jan 14, 2011 05:05 AM
firedad
Aug 16, 2003 01:12 AM
