early 99 differences?
Old Mar 1, 2007 | 05:21 PM
IDPisan's Avatar
IDPisan
The cut off date for the early 99 is 12-7-98, anything after that will be a 99.5. They changed some of the suspension after 3-1-99, so someone might have the older suspension with the newer motor.
The early 99 does have a smaller turbo but we don't experience the dreaded turbo surge that comes with having that bigger turbo. Injectors are 120cc for the early VS 140cc for the late 99. I beleive the HPOP is 15 degree on the early and 17 on the late. Stock HP is 235ish for the early, 250ish for the late.
When you start doing your mods it's important to tell your supplier early or late as it will effect your performance. Stick with the stamped dates as badges on doors or quarter panels are unreliable.
My 2 cents,
Jeff
Early 99 4X4 CC DWR, 6637,Straight piped, ISSPro gauges,pyro, boost, water temp, DP Tuner stock, 40tow, 60tow, 80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator. In that order .
Old Mar 1, 2007 | 05:27 PM
hucka1a's Avatar
hucka1a
Thanks to all of y'all.
Huck
Old Mar 1, 2007 | 08:04 PM
John311t's Avatar
John311t
I have almost converted my e99 to a late 99. All that is left to change that i know of is the hpop and injectors. The turbo is done, the brakes are done.
Old Mar 1, 2007 | 08:09 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Do the early trucks run a 110 or 120 volt IDM? I know that they still use alot of the early-model parts (HPOP and such), but there is an "in-between" phase for things like the injectors.
Old Mar 1, 2007 | 08:24 PM
aaron o.'s Avatar
aaron o.
Did you have to change the whole turbo assembly or just the wheel?
Old Mar 1, 2007 | 08:25 PM
PowerstrokeJunkie
He went all out, new turbocharger assembly, new up pipes, new compressor manifold, and i am not sure if he did the 3" plenums.
Old Mar 1, 2007 | 08:27 PM
John311t's Avatar
John311t
Read post #9--->here
Old Mar 1, 2007 | 08:28 PM
John311t's Avatar
John311t
Yup, i did the 3" manifolds also, you have to when you change the 5 way spider. I dont know about the IDM though, mine is modded anyways.
Old Mar 1, 2007 | 08:42 PM
aaron o.'s Avatar
aaron o.
Interested in getting rid of the 5 way spider?
Old Mar 1, 2007 | 08:49 PM
John311t's Avatar
John311t
If i had it i would. I left everything except my old turbo at the place i did it at. The guy i got all my stuff from had an OBS and wanted to add an inter cooler to his truck so i just gave it to him.
Old Mar 1, 2007 | 08:54 PM
aaron o.'s Avatar
aaron o.
Yeah, thats what I'm doing. The spider is all I'm lacking now. Seems as soon as I started looking for one, they quit popping up on ebay. Oh well, the hunt is still on. Thanks
Old Mar 1, 2007 | 08:58 PM
John311t's Avatar
John311t
You could always do the complete swap to a 99.5+ turbo. Then you could also run a turbonetics or a BB turbo also. Linky
Old Mar 2, 2007 | 04:54 AM
  #28
aaron o.'s Avatar
aaron o.
Wow, thats very tempting but I'm trying to go the lowbuck route. Thats definitely a nice alternative though!
malodin
Jul 4, 2010 01:27 PM
shanksyamaha
Mar 31, 2009 10:40 PM
drewk
Dec 4, 2006 08:06 PM
wfmcbride
Nov 15, 2006 09:15 PM
SuperDutyF250
Oct 25, 2005 10:49 AM
