460 fuel problems
Old Feb 28, 2007 | 06:46 PM
560farmall's Avatar
560farmall
Unhappy 460 fuel problems
hello got a 89 f250 that only wants to run for about ten minutes then shut dwn put a new fuel pump on it and it still acting up just like it runs out fuel help please
Old Feb 28, 2007 | 07:13 PM
55 binder's Avatar
55 binder
did you replace the fuel filter?
Old Feb 28, 2007 | 07:38 PM
560farmall's Avatar
560farmall
yeh i replaced it twice and it still doin the same thing it start good like nothing wrong then all sudden it die on me
Old Feb 28, 2007 | 07:55 PM
fordman16b's Avatar
fordman16b
Mabe its not a fuel problem??
After it shuts down, see if theres any fuel pressure left in the injector rail. That sould help diagnose the problem. Good luck =Mike
Old Feb 28, 2007 | 07:58 PM
560farmall's Avatar
560farmall
hello fordman i checked that and there is sum pressure left maybe it electrical dnt know
Old Feb 28, 2007 | 08:01 PM
fordman16b's Avatar
fordman16b
It just seems like an electrical problem to me. However do you know if it has an in-tank high pressure fuel pump or is the high pressure pump on the frame?
Old Feb 28, 2007 | 08:05 PM
560farmall's Avatar
560farmall
its in the tank what do u think could be in electrical
Old Feb 28, 2007 | 08:08 PM
fordman16b's Avatar
fordman16b
If it had the high pressure pump on the frame sometimes the low pressure pump in the tank goes bad and will make a truck do that.
Im thinking it could a sensor gone way bad or pcm. Does it slowly start to sputer and die or does it abruptly die?
Old Feb 28, 2007 | 08:11 PM
560farmall's Avatar
560farmall
it acts like it just runs out of fuel then dies sumtime it drop rpms then pick back once r twice then die
Old Feb 28, 2007 | 08:18 PM
fordman16b's Avatar
fordman16b
That's kinda stumping me. For kick's I would try pulling the pip, a little black jumper plug in the wiring harness near the TFI module on the rear of the drivers side fender. This bypasses many sensors, and makes the truck run in a "fail safe mode". If it stays running i would say its electrical or a wiring problem. You could also try jumping the fuel pump relay. If this works, i would say pcm. For some reason the PCM may be letting the fuel pump turn off. Just my .02 Good Luck
P.S.
I'm sure Frederic (another FTE Member) will chime in here at some point. He's a 460 master, and I know he would be more help than me.
