fuel return line
Old Feb 26, 2007 | 01:05 PM
tradecki's Avatar
tradecki
fuel return line
I would like to know if a 1989 f150 has a fuel return line or would i have to install one.
Old Feb 26, 2007 | 10:37 PM
nighthawk285's Avatar
nighthawk285
fuel injected or carburated?? why would you have to install one? what are you doing in that you are curious? a little more info would be great
Old Feb 27, 2007 | 11:17 PM
tradecki's Avatar
tradecki
it is EFI, but a am putting in a carburated motor in it that has 450 hp. and am using the intank fuel pump, but i have to turn down the fuel pressure so i need a return line.
Old Feb 28, 2007 | 01:18 AM
kell104's Avatar
kell104
Since it is currently EFI it does have a return line.
Old Feb 28, 2007 | 03:09 AM
nighthawk285
however....I do not believe that carburated models had a fuel return line, so you might be able to just plug it off.
Old Feb 28, 2007 | 06:00 PM
tradecki's Avatar
tradecki
i need the return line cause of the pressure in-tank fuel pumps make about 45-55 psi and carb. only needs 7-9 psi so the rest of the fuel needs to go back to the tank.
Old Feb 28, 2007 | 08:28 PM
nighthawk285
Are you sure about that in-tank pump pressure??? On these trucks, it only supposed to have about 45 psi at the fuel rail....and thats AFTER the high pressure pump....just something to look at.
