Sponsored by: Auxito
manifold to headers
Old Feb 28, 2007 | 04:59 PM
c_cort's Avatar
c_cort
manifold to headers
alright so im sure there's some one else on here who is tirred of hearing there manifold leak. i got the gasketreplaced on the passenger side, and then a couple weekslater my driver side started leaking and now they're both leaking. does anyone elsehave this proiblem? but myreal question is what are some good options for going with headersand how hard are they to install? i figure if im gonna drop the money on new manifolds i might as well just buy some decent headers. any input is greatly appreciated
Old Feb 28, 2007 | 08:17 PM
burninfordrubber's Avatar
burninfordrubber
Your manifolds are pobably worped and need replaced as well.....
Old Feb 28, 2007 | 11:23 PM
73f350sc's Avatar
73f350sc
If you can find headers that will work with your truck I say go for it, might even me cheaper than new manifolds...you'll gain a couple ponies and get a nice deep tone as well. Just keep in mind that you may have to have some welding done at an exhaust place to pipe everything together....all in all shouldnt be too hard on the pocket book.
-Chris
Old Mar 1, 2007 | 11:43 AM
sdeforest's Avatar
sdeforest
I'm getting ready to put some headers on my 97. I've been poking around this site to get as much information a possible. The only thing holding me back is that I read that the right motor mount is in the way of a couple manifold bolts, which it is because I checked, and I've been looking for someone that has put manifolds or headers on to see how they delt with this problem.
Old Mar 1, 2007 | 06:09 PM
lariat97's Avatar
lariat97
I put headers on my 97. I jacked the motor up to put in those bolts. Its a tough job putting the headers on. It took me about 8 hrs. I pulled the fender liners to give access to the motor
Old Mar 3, 2007 | 01:20 PM
tinman67's Avatar
tinman67
What brand headers? Any stud problems? What about fit and clearances? How do you like the final outcome? Come on man give us some details!!! Ther are a lot of us out here thinking of doing this project. Any info is very much appreciated.
Old Mar 3, 2007 | 01:47 PM
lariat97's Avatar
lariat97
I used JBA headers. They fit ok except for the EGR line. I had to bend it a little to make it fit. I gained some power but not as much as the long tubes I had on my last truck. The headers came with new studs & gaskets. I've put 60,000 miles on them with no leaks or problems. I'd use Dynomax long tubes if I was doing it again. Its a hard install but if you have the patience it can be done in a day.
Old Mar 3, 2007 | 02:26 PM
tinman67's Avatar
tinman67
Thanks for the info. I suppose the long tubes would require a custom exhaust? Do the short tubes fit inplace of manifold without exhaust mods?
Old Mar 3, 2007 | 02:36 PM
peppermrj's Avatar
peppermrj
The studs/bolts attaching the y pipe to the manifolds have rusted tot he point that they are as thins as a 30 amp fuse filament. I believe I will have to replace the manifolds just for those let alone anything else. Here is a link for headers I found. Dont know a thing about them so any input would be appreciated. The headers are not pictured. One link s for black the other is for armour cout (silver).
http://www.autopn.com/store/pc/viewP...dproduct=14041
http://www.autopn.com/store/pc/viewP...dproduct=14194
Old Mar 3, 2007 | 02:52 PM
peppermrj's Avatar
peppermrj
The other options is a set of cheapies from e-bay. Anybody have experience with those 30 dollar manifolds?
http://cgi.ebay.com/ebaymotors/EXHAU...mZ330092346344
http://cgi.ebay.com/ebaymotors/EXHAU...mZ330092641749
Old Mar 3, 2007 | 03:21 PM
peppermrj's Avatar
peppermrj
Old Mar 3, 2007 | 03:51 PM
lariat97's Avatar
lariat97
Don't buy cheap headers. They will not last. The Doug Thorleys are a good brand. I have shorty headers now & they bolt to the existing pipes
Old Mar 5, 2007 | 10:45 AM
sdeforest's Avatar
sdeforest
Thanks lariat for the input. I guessing you removed the 13mm bolts from the bracket bolted to the engine block and then jacked the motor up a little bit?
Old Mar 5, 2007 | 06:43 PM
peppermrj's Avatar
peppermrj
http://www.partsandaccessories.com/a...1998&partid=24
Old Mar 6, 2007 | 07:34 AM
Johnny Langton's Avatar
Johnny Langton
lariat97's right-inexpensive or lesser quality headers that aren't designed with trucks and towing in mind will crack,and leak in a short time. Towing is hard on manifolds and headers due to higher than typical exhaust gas temps under heavy load,so you need thick tubing and flanges if you expect them to last-otherwise the metal will burn out and fail.Typically they crack and warp pretty quick.
JL
