Car Spewing Coolant
Old Feb 28, 2007 | 12:30 PM
fmrplt's Avatar
fmrplt
Car Spewing Coolant
As I was driving home this morning I noticed a little bit of white smoke behind me. I know that usually means coolant leaking somewhere. I pull in the drive and smoke starts coming up from under the hood. I pop the hood and I found coolant coming out the bottom of this thing the arrow is pointing to in the picture. I can't find it anywhere in the book as to what the thing is. It's attached to the hoses going to and from the heater core. Anybody know what this thing does?
Old Feb 28, 2007 | 01:49 PM
mikeinri's Avatar
mikeinri
I assume this is a Gen 1 Explorer?
That's a valve that uses vacuum to control coolant flow to the heater core. It's like a $25 part at the Ford dealer. They told me they are a common failure item. I have seen them at after market stores (websites) also, such as Advance Auto Parts.
Extremely easy part to replace. I replaced my heater hoses at the same time, the one going to the water pump was a pain because of a bracket that keeps it away from the belt.
Hope this helps.
Mike
Old Feb 28, 2007 | 02:46 PM
fmrplt's Avatar
fmrplt
Thanks Mike, got it changed and the coolant is staying where it should. I'm happy again.
Old Feb 28, 2007 | 02:53 PM
mikeinri's Avatar
mikeinri
"...the coolant is staying where it should..."
My boss has an old Air Force saying when dealing with electronics... "NEVER let the smoke out!"
Or, in the case of coolant, never let the steam out!
Glad you got it fixed. I wish all the problems were this simple.
Mike
Mr Boogie
6.4L Power Stroke Diesel
31
Feb 17, 2017 07:39 AM
Jeepincj7
17
Jan 27, 2014 09:43 PM
skinny29286
Jan 25, 2014 06:46 AM
BROWN-BOMBER
36
Nov 16, 2011 08:44 PM
mind
May 19, 2008 08:26 PM
