hook tool?
Old Feb 28, 2007 | 05:14 AM
jerryh20's Avatar
jerryh20
Question hook tool?
76 f100 - remove instrument cluster - book says use hook tool to remove wiper switch - what is that?
Old Feb 28, 2007 | 05:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Are you trying to remove the ****? Rotate it till you see a cutout. Stick a small nail into that cutout and you will contact a spring loaded device that holds the **** to the shaft. Push that forwards or backwards (forget which) and **** will pull off. Headlamp switch **** and shaft comes off as a unit, btw.
Once the **** is off, there's a nut that holds the wiper switch to the dash bezel.
Remove one battery cable to prevent a possible short from any tools you are using!
Old Feb 28, 2007 | 06:03 AM
SoArkSI's Avatar
SoArkSI
on some vehicles that only works on the headlight switch, and even on the air and radio controls, there is a little tab on the **** behind it and you take a really small screw driver or hook tool and pull back on that tab and pull the **** off. and the hook tool looks just like that picker hook that a dentist has, just somthin easier than a small screwdriver to release that tab on the *****
Old Feb 28, 2007 | 06:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
Any tool or bent piece of metal that will reach in behind the **** can be used to pull the spring clip towards you. When the clip is pulled the **** will slide off the shaft.
For headlight **** instructions check the Read First: FAQ thread at the top of the 73-9 forum for info.
Old Feb 28, 2007 | 06:41 AM
NumberDummy
Most of the Ford headlamp switch **** and shafts come off as a unit. Just reach up under the dash till you find the switch. On the bottom of the switch, there's a spring loaded button...press that in..pull off **** and shaft.
Old Feb 28, 2007 | 08:18 AM
jerryh20's Avatar
jerryh20
Post bulbs in dash
you guys give great advise - i appreciate the info - better than any book
I have looked at the forums to find my dash light problems - it has seven bulbs, none of them working - all gauges working - lite switch working - will start with the fuse,looks ok but will test it - check connections at cluster
and then remove to check bulbs.
thanks again
in the cluster - will take
Old Feb 28, 2007 | 12:32 PM
Mil1ion's Avatar
Mil1ion
I just use a jewellers screwdriver and insert it in the slot and pull it and the **** away from the shaft.
I think I'm going to make a picture of this procedure and have it posted in the FAQ thread where all the GREAT info is that people don't look at.
Attention people :Read the Read First: Thread
Old Feb 28, 2007 | 12:37 PM
NumberDummy
and then remove to check bulbs.thanks again in the cluster - will take
Rheostat in headlamp switch goes bad, you won't have any dash lights. Turning the ****, brightens or dims the lights. Replacing the H/L switch is a step forward after other tests have failed.
D3ZZ-11654-A Headlamp Switch (Motorcraft SW-1245)
Old Feb 28, 2007 | 12:45 PM
Mil1ion's Avatar
Mil1ion
Just make sure the battery is dsconnected first and the headlight switch is in the ON position before depressing the button.
Old Feb 28, 2007 | 04:01 PM
Mil1ion's Avatar
Mil1ion
X36's Avatar
X36
Get a nice set of picks and use either the 90 degree one or the curved one for the wiper ****.Works well for me Regards
Old Feb 28, 2007 | 04:09 PM
NumberDummy
Dennis, you are absolutely amazing...talk about dedication...if a pic is required...you have it.
I wouldn't be surprised if you had a pic of a Belanese dancing girl doing the macarena on the hood of a 65 Mustang.
Old Feb 28, 2007 | 04:12 PM
bucks77ford's Avatar
bucks77ford
Awesome......
Old Mar 1, 2007 | 09:21 PM
ihateminimumwage's Avatar
ihateminimumwage
As NumberDummy put it, Rheostat in headlamp. Had the same problem with mine just a couple of weeks ago (Thanks again, NumberDummy, Torque1st, Mil1ion, and all others that helped me out, as usual)
Just replace the whole switch. They're $11.99 on the Kragen website (as much as I dislike them, it's way better than the $40-50 you'll pay in store, and everywhere else).
