DP-tuner pcm flash
Old Feb 27, 2007 | 03:24 PM
highboy390fe's Avatar
highboy390fe
DP-tuner pcm flash
I have a 2001 f250 7.3 118,000 miles I am wanting to send in my pcm to DP-tuner to get it flashed, Can you get any of the tunes flash on it, and if so what tune do you recommend, its pretty much my daily driver except very occasional towing of 6000# trailer and a car hauler with my 73 mud truck on it. What tune would you guys recommend? Thanks
edit: I also live in wisconsin does this affect cold starting? Thanks
Old Feb 27, 2007 | 03:30 PM
CSIPSD's Avatar
CSIPSD
If your going to get a flash, just get the 80 tow and you will be fine... But I would really look at a chip over a flash... The ability to adjust is priceless.
Old Feb 27, 2007 | 03:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Go for the 80hp Econo flash. Tell jody to try to work out the "fuel lag" (as i call it) in the lower RPM's. On my 80 econo program, there is a definite fuel lag programmed in to prevent smoking until the turbo begins to spool up. I use that setting the most, and alot of guys here have a 80hp flashed PCM.
Old Feb 27, 2007 | 06:28 PM
nlemerise's Avatar
nlemerise
Why send your PCM? Just have Jody send you a pre-flashed PCM of your choice. When it gets there, replace your PCM with his and mail the old PCM back to Jody. I was without my truck no more than 30 minutes . I got the 40 tow PCM and I am still happy I did.
Old Feb 27, 2007 | 07:59 PM
bigtorque's Avatar
bigtorque
according to jodys site, you can no longer send your pcm back as a core and recieve the 175 bucks back.
not sure why. maybe he has enough cores. so, the flash is 75 bucks plus shipping,
for any performance tune, or 250 bucks for his supplied with flash. and the flip chip
$245 with one tune and 45 for each additional.
Old Feb 27, 2007 | 10:07 PM
empiretc's Avatar
empiretc
Nope. He told me on the phone they took a pretty bad hit getting back a bunch of bad PCMs. Some people just plain SUCK. The flash comes out to ~$100 after shipping and all. I LOVE IT!!
Old Feb 28, 2007 | 08:40 AM
nlemerise's Avatar
nlemerise
That is sad to hear...always has to be some a****** to ruin it for others.
Old Feb 28, 2007 | 08:56 AM
aklim's Avatar
aklim
Not sure you want the 80 Econo if you tow. I had a 60 because 80 Tow made too much heat for my stock system . I have a 4 in MBRP and DP Tuner VB at the time.
Old Feb 28, 2007 | 10:44 AM
CSIPSD's Avatar
CSIPSD
That just blows my mind... I could tow in the 125 setting before injectors with no issues... Control the EGT's with your right foot...
Old Feb 28, 2007 | 12:54 PM
highboy390fe
Thanks guys for all the quick answers, i think i will be going with the 80 econo until i can afford the actually chip so i can get the higher settings and really smoke people
Old Feb 28, 2007 | 01:54 PM
aklim's Avatar
aklim
I asked Jody about the 80HP Tow tune and he felt it was too high. He recommended the 60HP Tow tune instead.
Old Feb 28, 2007 | 07:15 PM
GoCamping's Avatar
GoCamping
I went with the 40hp tow tune for my ~9k 5th wheel. My EGTs stay in check so well that I rarely have to check them (just a quick glance going up hills). However - they were out of control when I had boost leaks. Nervewracking. And how did I know I had boost leaks? Gauges! Imagine what damage I could have done if I ran 40hp tow with those boost leaks....
Having said that, you could go with 60hp tow for only a 6000lbs trailer. Of course, ask Jody for a definitive answer. But get gauges. BTW the flash is a great deal. I have to feed my PMS on a budget...
Old Mar 1, 2007 | 12:51 PM
highboy390fe
I have to control what I spend to, I havent even had my truck for a month yet, and i could have spent alot more.
Old Mar 1, 2007 | 02:46 PM
sean23johnson's Avatar
sean23johnson
i dont want to hijack this thread but i have to ask. how did you find your leak? did you pressurize the system w/compressed air?? how high were your egt's w/the leak?? also what did you do to fix it??
Old Mar 1, 2007 | 04:54 PM
GoCamping's Avatar
GoCamping
I have to admit I didn't really "find" them, I just saw the obvious - y-pipe to engine intake boots that had slid from where I originally installed them, and a clamp that was definitely not doing any good (at an angle and 'loose'). So I figured since I had to take it all off, I replaced them all (including the intercooler boots) and filed the y-pipe while it was out as well.
Before, and without the pcm flash, I could push 1250 easily. If I didn't let up going up some not so steep hills, I could see where it would go right through 1300. Obviously didn't want to do that, so I spent alot of time climbing hills in 3rd going 55 (one time I had to do 2nd at 40). I was left wondering if all trucks were like that. Then some threads about "hissing under the hood" got me thinking and I looked closely at my y-pipe and "voila" as they say...
Now I go up the same hills, with the 40hp flash, boost leaks fixed (and I did get the BTM) and it's much lower. In fact I could probably go to the 60hp because I have more "room" ...
- - - by the way I did make a boost leak detector like that sold on dieselsite, it did help me also. I determined that my intercooler boots were not leaking but I replaced them anyway - - -
Jesser02EX
Aug 16, 2015 10:42 PM
bizzelj
Apr 19, 2015 12:56 AM
Pigman54
Ford Truck Parts for Sale
Nov 2, 2014 08:02 PM
Blue7.3
Australia Chapter
Oct 1, 2014 03:50 AM
Robert6401
Aug 7, 2006 02:37 PM
