radiator coe support
Old Sep 19, 2014 | 01:49 PM
Andy1966's Avatar
Andy1966
i need a 66 radiator core support.......i know i just heard all of you laughing!!!! is there anyway i can use a different support now that im changing engine and radiator? Can i modify a earlier or later core support? This is one of the last parts i need!!!
Old Sep 19, 2014 | 02:06 PM
Jon003's Avatar
Jon003
This link may help you I believe: https://www.ford-trucks.com/forums/1...or-66-use.html
Old Sep 20, 2014 | 01:26 PM
TxStang2010's Avatar
TxStang2010
use the 1965 core support . difference is the battery tray mounting and the radiator mounting hole locations , both are easily fixed . They both use the straight inner fenders and will bolt right up to them in place . Mac's sells them
Old Sep 20, 2014 | 05:20 PM
Rbeck204's Avatar
Rbeck204
I have a new 65/66 radiator support that I am not going to use. $300 plus shipping. Never used. No modification necessary.
Rich
Old Sep 20, 2014 | 07:45 PM
customcab66's Avatar
customcab66
I used a 65 the only thing I had to change was the radiator an tha was no big deal had to replace it any way
Old Sep 20, 2014 | 08:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which radiator support has recently been repro'd that LMC, Mac's and etc are selling? AFAIK, it's the one for 1966 F100/250 2WD
C6TZ-16138-B .. Radiator Support / 1965 F100/250 2WD & 1966 F100 4WD
C6TZ-16138-C .. Radiator Support / 1966 F100/250 2WD
Old Sep 20, 2014 | 11:04 PM
TxStang2010
65 F100 2wd , we just put one in a 66 F100 2wd and used the 65 radiator and mounts and made the battery tray fit to it as well . a few other things like holes for the horn relay to screw to and minor things like that were easily fixed as well .
Old Sep 21, 2014 | 04:44 PM
1964FORDTUF's Avatar
1964FORDTUF
Does anyone make a repro for the 64 4X4?
Old Sep 21, 2014 | 06:13 PM
schoo's Avatar
schoo
No and I though it was only surface rust you might try the bigger trucks I think that some use the same core
Old Sep 21, 2014 | 06:54 PM
1972RedNeck's Avatar
1972RedNeck
I know where there is a solid original one that's only 2400 miles away from you .
Old Sep 21, 2014 | 08:32 PM
NumberDummy
Originally Posted by schoo
No and I though it was only surface rust, you might try the bigger trucks I think some use the same core.
Geez Louise, I've typed 100's of posts on this topic listing the part number and the applications as have other members.
This radiator support is reproduced and has been available from multiple sources...for at least the past 6 years!
C2TZ-16138-G .. Radiator Support / Reproduced
1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD
Old Sep 21, 2014 | 10:17 PM
schoo's Avatar
schoo
Sorry bad info
Old Sep 22, 2014 | 07:06 AM
1964FORDTUF
Well ND, thanks for this however the vendors Ive checked seem to denote not for 4x4. If you know of a vendor that sells these and does not say "not for 4x4" I would appreciate you passing it along. Thanks again.
Old Sep 22, 2014 | 07:13 PM
1964FORDTUF
If your thinking of parting it out...Im sure theres a few more items I can take off your hands that shipping wont be as much as the whole enchilada...
Old Sep 22, 2014 | 08:49 PM
NumberDummy
The fact that certain vendors are stupid .. ain't my fault. It's theirs since they don't have Ford truck parts catalogs to look up the applications.
C2TZ-16138-G = 1961/64: F100/250 same for 2WD & 4WD and F350/600 and B500/600 (School Bus) // 1965 F100/250 4WD / 1965/66 F350/600 / 1965/66 B500/600 / 1966 F250 4WD
1964/72 & 1957/63 parts catalog applications:
