1978 - 1996 Big Bronco
Rear Window
Old Sep 19, 2002 | 08:29 PM
astamp78's Avatar
astamp78
Rear Window
I have a 1978 Ford Bronco 4x4 that I have been working on for about 4 years and has come along quite well. One thing that I just cant seem to accomplish is a rear window that works correctly. The key switch is broken and I know that that one is expensive to replace unless any of you know of a cheaper one. (i priced it at something like $200 I think). The main problem is the window just doesnt go up and down well at all. I replaced the motor with a new one which helped some but still would slow down and stop on the way up (and down). I then replaced the spring arm assembly with a new one and still it doesnt work worth a darn. I dont know what to do. ANy thoughts?
Andrew
78 ford bronco custom 4x4
460, c6
Old Sep 19, 2002 | 08:35 PM
Sooliman's Avatar
Sooliman
Rear Window
Have you replaced the weatherstripping?
Believe it or not, hardened weatherstripping (that which is no longer pliable) is likely the culprit. I had similar problems a passenger side door on a previous Bronco. I thought it was a bum window motor. I'm assuming that the body is straight (i.e. the tailgate closes flush).
Old Sep 20, 2002 | 09:08 AM
JBronco's Avatar
JBronco
Rear Window
Mine actually WAS the motor, but you also want to make sure that you have grease on the regulators (the tracks where the metal slides back and forth, connected to the window). Also, I actually grease the weatherstripping, this also keeps the window from squeaking when it is rolled up and the weatherstripping is dry.
Old Sep 22, 2002 | 10:23 AM
astamp78's Avatar
astamp78
Rear Window
The weather stripping is new. The tailgate closing flush might be worth some checking. It is an aftermarket tailgate....thought I could save some money, what a peice of junk. It is thin and lightweight, the torsion bar spring actually caused the inside to pop out a bit. Anyway, it closes flush but the tracks might not lign up, shims maybe?
Thanks
Andrew
Old Sep 22, 2002 | 11:17 AM
mudbug79's Avatar
mudbug79
Rear Window
Big_Red_Brute
30
Aug 20, 2024 07:36 PM
darmento
Aug 2, 2016 03:07 PM
bbygirl778
Oct 3, 2015 02:42 AM
tassmannn
Aug 28, 2014 07:38 PM
the Goat
Jun 30, 2006 04:31 PM
