Ideas for a power roll-down rear window
I just bought a book off of Ebay that shows all the Ford Authorized accessories for the 1990 line-up of Ford trucks, SUV's, and vans. While looking through it, I found a kit for a power roll-down rear window that was avalible for these trucks. The P/N for the kit was 10422C30. Now I'm sure that you'd never find one NOS, but I'd like to know if anyone knows where I could find a kit to do this. There has to have been an aftermarket company somewhere along the lines that made a kit like this. I must say that I've never seen this on a truck, I know that some newer "Brand-X" trucks have them. If you have any ideas on how this could be done using a full-size Bronco rear window, I'd be open to those as well. The thing I can't figure out there is what to do about the stock window opening, and how to get an upper track for the window to slide in. The glass part will work for the most part, as will the power window motor. Thoughts anyone???
The rear window of the whatever-96 F-series is flat. Flat means you have more options than curved, and by that I mean you can size a window to your liking and frame opening by visiting a glass store. The rear window should be safety glass much like is used on school buses and of course, coffee tables.
Tracks, well, it's nothing more than a c-channel with weatherstripping. Companies like JCWhitney sell generic weatherstripping by the foot, so you can easily buy it long enough to go up each side and across the top with one piece, or maybe miter the corners, those kinds of details I myself haven't figured out.
The bottom would be an ordinary piece of weather stripping much like the Bronco - attached to the frame of the window and rests on the glass pointing up to shed water property. If slightly oversized lengthwise, it might make a good seal on both sides, just the way the did it on the Bronco.
Movement of the window seemed easy - any larger sissor mechanism from either the Bronco itself or any of the land-yacht sized station wagons made in the 70's would be a good choice - many of the full-sized Chevy, Ford and Buicks had full power rear windows actuated by a switch in the tailgate itself or on the dashboard. Switch choice not-withstanding, the mechanism probably would be a good place to start. Many aftermarket "add power" units work using a plastic "stalk" and have a pulley on the top and the motor and a pulley on the bottom, moving a cable around. The window has a clip and that clip hooks to the bottom of the window. There are a lot of choices.
Another option I considered was to take my factory solid rear window out and bring it to a local glass shop who assured me they could make four holes of any size along the top of the glass, for the mounting of Ford Explorer hinges. While not powered, I could flip the window up and drive around. Add two gas supports to keep it open. The glass shop said they could do this using their waterjet glass cutting machine - it's CNC controlled. They also wanted $15 a hole, and I'd need six if I used gas supports.
Again, I've kicked this around for years and never get to building it. I've also kicked around the idea of extending the frame a couple of feet and added the rear section of an extended cab behind my crewcab, mostly for storage space. Crewcabs have about as much storage as a regular cab, because the rear seat is right against the back wall. But of course, I never got to that either. By the time I do, I'll have to buy new c-channel and weld up a new frame from scratch, and then I can make the crewcab it any length I want.
But, I'm just a nut with too many ideas. No warranty
EDIT: I stand corrected......never heard of that option...I've seen two of the power sliders but not that style...
From what I remember this was a option that he added when he bought the truck new.
I remember it being some what sunk-in 1/2in and basically same design as a car sunroof where the whole assembly came complete. Once they broke his window and it was the same piece as a original back glass, but a real pain to put in
I'll get pics next week...
My F150 also has turn signal mirrors really hard to come across those mirrors since some 1996 Broncos came with them and they are factory OEM the ones I have !
KIT (POWER BACK WINDOW)
</TD><TD id=row0_cell_1 class=resultRow3 vAlign=top noWrap>E8TZ-10422C30-A
</TD><TD style="DISPLAY: none" id=row0_cell_2 class=resultRow3 vAlign=top>422C30</TD><TD id=row0_cell_3 class=resultRow3 vAlign=top> </TD><TD id=row0_cell_4 class=resultRow3 vAlign=top>Clear, (Regular Cab), 1981/1989 ; Ford 150 Series
</TD></TR></TBODY></TABLE>
<TABLE id=TableSearchResultGrid class=text cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR id=row1 height=15><TD id=row1_cell_0 class=resultRow3 vAlign=top></TD><TD id=row1_cell_1 class=resultRow3 vAlign=top noWrap>E8TZ-10422C30-A
</TD><TD style="DISPLAY: none" id=row1_cell_2 class=resultRow3 vAlign=top>422C30</TD><TD id=row1_cell_3 class=resultRow3 vAlign=top> </TD><TD id=row1_cell_4 class=resultRow3 vAlign=top>Clear, (Super Cab) w/o rear bench seat, 1981/1989 ; Ford 150 Series</TD></TR></TBODY></TABLE>
<TABLE id=TableSearchResultGrid class=text cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR id=row2 height=15><TD id=row2_cell_0 class=resultRow3 vAlign=top></TD><TD id=row2_cell_1 class=resultRow3 vAlign=top noWrap>E9TZ-15422C30-A
</TD><TD style="DISPLAY: none" id=row2_cell_2 class=resultRow3 vAlign=top>422C30</TD><TD id=row2_cell_3 class=resultRow3 vAlign=top> </TD><TD id=row2_cell_4 class=resultRow3 vAlign=top>Tinted, (Regular Cab), 1981/1989 ; Ford 150 Series</TD></TR></TBODY></TABLE>
<TABLE id=TableSearchResultGrid class=text cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR id=row3 height=15><TD id=row3_cell_0 class=resultRow3 vAlign=top></TD><TD id=row3_cell_1 class=resultRow3 vAlign=top noWrap>E9TZ-15422C30-A
</TD><TD style="DISPLAY: none" id=row3_cell_2 class=resultRow3 vAlign=top>422C30</TD><TD id=row3_cell_3 class=resultRow3 vAlign=top> </TD><TD id=row3_cell_4 class=resultRow3 vAlign=top>Tinted, (Super Cab) w/o rear bench seat, 1981/1989 ; Ford 150 Series</TD></TR></TBODY></TABLE>
