1978 - 1996 Big Bronco
gears
Old Sep 23, 2002 | 03:23 PM
aj5601's Avatar
aj5601
gears
i have a 79 bronco, and i was looking for the tag that tells the gears. well i didn't find it! is there any other way to tell my gears besides lifting the rear end up and spinning the tires? is it on the vin at all? or did they only come with one set of gears, i was told it might be 3.50 gears and if they are i need to know so i can save up for a set of 4.56
Andy
Old Sep 23, 2002 | 04:12 PM
ryanguglich's Avatar
ryanguglich
gears
>4.56
>Andy
most broncos have a AXLE code in the drivers door sticker. I don;t remember the codes but they're easy to find ina search engine.
The TONKA Project Continues...
1981 Bronco 302 Gutted, Fenders cut, Custom bumbers coming, (spray in) Box Liner inside and out, Roll-bar etc
Old Sep 23, 2002 | 07:13 PM
mudbug79's Avatar
mudbug79
gears
Well Andy I'll tell ya.You probabaly have 3:50's.And to install 4:56 you need to buy ring/pinion and differentials.Cause the differential diamiters are different on the 3:50 and the 4:56.3:50 will go to 4:11,that way all you need to do is ring and pinions.Good luck
Old Sep 23, 2002 | 07:47 PM
bronco cam's Avatar
bronco cam
gears
You probably have 3.55 not 3.50 there should be a tag on your diff if not there is a code on the door sticker that will tell you. Randys ring and pinion makes 456 gears for all kinds of diffs I am not sure what you have but I highly dought you need to trade your diff housing to get 456 gears. I have done several gear swaps in my fords and never have changed a housing. They even make 456 gears for ford ibeam housings such as a dana 50. You probaly have a dana 44 front solid axle and I am not sure about your rear. Find out what you have and give randys ring and pinion a call.
Old Sep 24, 2002 | 12:15 PM
sclemons's Avatar
sclemons
gears
Old Sep 24, 2002 | 12:16 PM
aj5601's Avatar
aj5601
gears
thanks for the help guys. if i have to change everything, i think i will just stick with 4.11. save me some money, other wise if all i need gears then 4.56 it is.
Andy
jomes
Feb 27, 2006 07:35 AM
GTBksRule
Jun 20, 2005 05:12 PM
andy_s
Jul 23, 2003 11:43 PM
gray79f250
Jul 26, 2002 10:56 PM
