Modular V10 (6.8l)
lash adjuster failure
Old Feb 26, 2007 | 12:36 PM
rhino3's Avatar
rhino3
My 99 V10 superduty popped when I started it a few days ago and being short on time I took it to the local blue oval shop to have them diagnose. Turns out the lash adjuster broke/failed and was keeping the valve open causing low compression on #2 cylinder. Recommendation is to replace all lash adjusters per Ford TSB. Anyone had this happen yet?
Thanks,
rhino3
Old Feb 26, 2007 | 01:22 PM
biz4two's Avatar
biz4two
Arrow
Wow...hope you caught the issue in time...so it did not harm the rest of the V10. Good luck with it!
Question: Does anyone know how intrusive it is replacing a lash adjuster? I'm just curious...
biz
Old Feb 26, 2007 | 01:36 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'm pretty sure you can replace them without even removing the cam.
I've heard of earlier 4.6's were known, after sitting for a long time (and the lash adjuster bleeding down) to throw the follower.
But '99 sounds pretty late for that. Just a plain 'ole mechanical failure.
Like I said, it's a cake-walk... hopefully
Old Feb 28, 2007 | 11:21 PM
rhino3's Avatar
rhino3
Found out that replacing the lash adjuster requires a combination of three different valve spring compressers depending on which cylinder you are working on. Cam removal is not necessary, this is the first failure the local shop has seen on a V10. Parts cost approx $25 labor cost approx $180, just replacing the defective one this time I guess if it happens again I will replace the other 19.
rhino3
Old Mar 1, 2007 | 06:04 AM
FortyFords's Avatar
FortyFords
Depending on the mileage on this vehicle,what does start to happen is the valve guide will become worn as the valve lash adjuster wears it tends to push the valve to oneside and wears the guide out. this came back from the ford reman guys a few yrs ago.
The adjuster breaking is not uncommon on the modular motor.
Sometimes the piece gets lodged and takes out the cam and can keep the valve open when the piston comes up not a pretty sight.
To the orignal poster consider there proposal on replacing all of them now or do it yourself with the tool.
Rich
Old Mar 1, 2007 | 04:00 PM
biz4two's Avatar
biz4two
Thumbs up
rhino3
Appreciate you reporting back! Glad to hear you are back on the road...
biz
Old Mar 1, 2007 | 07:46 PM
1's Avatar
Was this issue resolved in later years? Like say in 03 perhaps?
Old Mar 1, 2007 | 09:06 PM
krewat's Avatar
krewat
Personally, I haven't heard of any differences on the top end after '94 or so in the 2-valve modulars.
2005 and up, it's 3-valves, so those are different... but...
shaw4825
2004 - 2008 F150
Jan 21, 2015 12:03 PM
C-700
May 28, 2014 10:32 PM
richartdana44
Mar 31, 2010 11:10 PM
Bikeitswift
Sep 22, 2004 10:23 PM
vnv
Bronco II
Aug 30, 2003 09:29 AM
