No spark!
Old Feb 25, 2007 | 11:32 PM
gearhead351's Avatar
gearhead351
Question No spark!
I have an 84 Ford F250 4x4 with a 351 Windsor. I am not getting a spark and I cant find the problem. Everything in the truck works and the motor still turns over. But no fire! I have no spark! I have an MSD-6AL unit, an MSD ignition coil, new wires, plugs, cap, rotor. I recently replaced the voltage regualtor and starter solnoide. Does my truck have a switch under the dash Ive heard about that turns off the ignition? I have heard also of fusable links but I dont know where they are. Please help! Thanks, Matt
Old Feb 26, 2007 | 01:07 PM
Franklin2's Avatar
Franklin2
Make sure you have voltage on the + side of the coil with the key in run and start. What distributor are you using? Are you still using the original ford module also?
Old Feb 26, 2007 | 02:08 PM
bgriffin09's Avatar
bgriffin09
mine had the same problem and it did turn out to be a kill switch under the dash...someone else had installed it aftermarket and it fell apart opening the circuit...i also had an LTD that lost spark and i replaced the module and fired right up.
Old Feb 26, 2007 | 04:45 PM
gearhead351
I still am using the stock MotoCraft distributor. As far as I know the module is stock.
Old Feb 28, 2007 | 01:49 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.c...stributors.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Feb 28, 2007 | 04:23 PM
mtflat's Avatar
mtflat
Shouldn't this be in the classified's???
Old Feb 28, 2007 | 04:29 PM
rdz's Avatar
rdz
check the spark box on the fender we had one come unpluged on are 84 t-bird but they are knowen to fail
Old Feb 28, 2007 | 07:15 PM
Franklin2's Avatar
Franklin2
If you think it's the stock electronic ignition box giving the trouble, I think there is a way for you to wire your stock dist to drive the MSD box directly. Go to their website and they have the instructions for your model MSD. Also they have special instructions for each type of dist and what options you have for wiring.
Schickel
Feb 20, 2014 04:28 PM
gearhead351
Feb 23, 2007 03:08 PM
smallblock351w
Apr 5, 2006 05:48 AM
79f150TX
Electrical Systems/Wiring
Mar 29, 2005 07:36 PM
Coondawg
Dec 7, 2003 02:37 PM
