MSD no spark
Old Dec 6, 2003 | 08:01 PM
Coondawg's Avatar
Coondawg
MSD no spark
Hello all.
I recently put a MSD 6 igntion and Blaster 2 coil on my 400. Well, it's not getting spark from the distributor. I done the test and spark is going to the distributor. Anyone have experience with this?
The truck is an '80 model. It has a factory distributor, MSD Heli-core wires (yes, they are going to the correct cylinders), Duraspark ignition.
Old Dec 6, 2003 | 10:18 PM
76390FE's Avatar
76390FE
you have spark going from the coil to the center of the ditributer cap??...but no spark to any of the plugs??
Am I understanding this right?...or not
Old Dec 6, 2003 | 10:57 PM
pfogle's Avatar
pfogle
Sounds like a faulty cap to me. If the coil is firing but the plugs aren't either you forgot to install a rotor under the cap or the cap itself is junk.
Old Dec 7, 2003 | 02:37 PM
Coondawg's Avatar
Coondawg
Yes, I'm getting spark from the coil to the distributor. The cap and rotor have been replaced but no change.
The distributor is turning. I had a buddy crank the engine and I watched the rotor turn.
The wire are routed correctly. I suspect the wires are not compatable with the MSD ignition.
410F-100
25
Dec 6, 2010 09:13 AM
410F-100
Dec 4, 2010 09:08 PM
86rustbucket
Mar 14, 2006 12:49 AM
Coondawg
34
Dec 21, 2003 08:07 PM
Lee 78F250
Dec 14, 1999 06:11 AM
