Need help with my C4
Old Feb 25, 2007 | 10:31 PM
p_charlan's Avatar
p_charlan
I need help with my C4. I have a 1964 F100 with a 289 & C4.
The problem is that it won’t go into park and shifter is backwards.
When I looked under the truck I saw that the arm on the transmission was down so I thought I should rotate the arm and make it up, when I unbolted it the shift arm did not come off is there a trick to pull it off? Any idea on the no park issue?
I appreciate the help.
Old Feb 26, 2007 | 03:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
you have a floor shifter trans setup. to reverse the shift arm, the trans needs to be partially disassembled.
the shift arm is held into the trans with a clip behind the valve body.
Old Feb 26, 2007 | 06:30 AM
stuart1's Avatar
stuart1
Do you haver a floor shifter installed?
If so the lever will have to be rotated.
Remove the valve body.
Remove the throttle lever.
Loosen the 15/16" inner nut.
Pry the rooster comb off the arm.
Turn the arm.
Usually floor shift transmission arms are shorter so you could run into problems.
Old Feb 26, 2007 | 09:22 AM
p_charlan's Avatar
p_charlan
Thanks i will keep you posted.
plum bob
18
May 31, 2018 12:06 PM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
jpj64
1983 - 2012 Ranger & B-Series
25
May 24, 2010 08:58 PM
jeff2011
Sep 7, 2009 10:54 PM
Technocrsr
Feb 17, 2007 09:13 AM
