my truck empty weighs my gvw rating
whats wrong with this picture?
I get on the scales at the quarry and weigh in at 6800lbs. or 3.4 on the meter, with just me in it, I weigh 220lbs. my door tag says gvwr 6850 wtf.
one time i had four buddies with me, we're all at least 200lbs. and loaded up gravel for one of them, thats a 1000lbs of people on top of 2000lbs of gravel added to 6800lb truck, almost 10,000lbs on a 6850 gvw. and im still starting off in second gear, never had to use granny yet.
its a crewcab all stock, 360, 4x4, stock rims and tires, when i measure the tires with a tape they come out to almost 29 in. I got a homemade approx. 300lb. front bumper on it, but i figure it evens out cause i have no bed floor, my bed is pratically a duraliner sitting on frame rails, and crossmembers. dual gas tanks. Nothing extra on the truck like a winch or dual batteries yet, hell i dont even have a spare tire on the truck when i go to weigh.
I dont feel like im being dangerous and unsafe, truck feels fine no rubbing or bottoming out, steering, braking, all feel adequate under load, am i being dangerous, or have i not even scratched the surface on what these trucks can do. I used to have an 84 f250 4x4, and it could take some abuse, but not like this 76.
the vin #'s match, and i used a decoder for the rest of the plate and all the codes match what i have on the truck, trans, body, wheelbase, everything.
on the same plate it says type/gvw F260, and max gvw 06850, also my vin starts F26
theres also a sticker on the door jamb on the body side, most of the sticker is unreadable, but what i can see it matches up with the plate riveted on the door.
your 7,500 gvw rating sounds more reasonable even though its a 6, mine should at least be that much.
My dad used to run into same problem with his 77 Crew cab. As for hauling safley. You can haul a house with it. If your brakes are good you should have no problem hauling (though not legally) that weight and more. The last 70's F250 I had would haul 2 + tons coal with no problems and stop just as good as the 90'F350 I drive now. It all what you feel comfortable with.
My 1978 E150 has a GVWR of over 6000...but it is registered at 11,000.....
It weighs 4950 empty, on band road trips with 5 people and all the gear/merch it weighs in at about 7500......the back tires rub because they are 31x10.5, but aside from that it does just fine and still gets 10+mpg!
Shake-N-Bake
EcoBoost (all engine sizes)
07-20-2015 11:52 AM
