I need some help
Old Feb 25, 2007 | 10:31 AM
streetrodcreed's Avatar
streetrodcreed
Unhappy I need some help
I have an 89 f150 4.9 2wd truck, and im have issues with the charging system.
this is what its doing, if i charge the battery then run the truck the amp meter never gets above halfway if i turn the lights on or stereo, or anything electrical the amp meter jumps down to red again. it usually starts right after its warm but not after it sits all night.
Ok this is what ive done so far, replaced positive wire (it was cracked) replace neg terminal lead on battery (cracked also) cleaned all the wires on the switch thats on the fender wall (2 broke stripped wire and put back on).
now the question is what else could it be or do i need a new altenator?
Thanks for any help!
Old Feb 25, 2007 | 10:41 AM
msgtg's Avatar
msgtg
I don't know if this will help or not but...
I just had my 92 F150 351 in the shop. I was having battery issues too but my battery was only a little over a year old so I suspected the alt as my problem. My mech says that yes, the alt needed to be replaced ($280 new) but that the culprit was the plug that plugs into the alt. It was fried...which in turn fried the diodes in the alt...which in turn killed the year old battery. Pull the plug and see if it's crispy or looks carboned.
Good Luck Dude.
Old Feb 25, 2007 | 11:11 AM
mhg's Avatar
mhg
first off take it somewhere and get it TESTED
Old Feb 25, 2007 | 07:02 PM
streetrodcreed
took the alt to autozone, it was bad and i installed the new one. drove about 10 miles and itt hangs around 13 amps but when i tur the heater fan on it jumps way down but slowly works back up to 13. any suggestions?
Old Feb 25, 2007 | 07:23 PM
wheily's Avatar
wheily
my truck has always doen that when the heater is turned on i figuer it normal
Old Feb 25, 2007 | 07:26 PM
wrenchturner's Avatar
wrenchturner
it's a volt meter in the dash and it's normal to dip initially when adding load to the system.
JimsRebel
'80-'86 HOWTO's
18
Jan 23, 2025 04:19 PM
GoneFishen
Jun 14, 2010 08:14 PM
kawa
25
Sep 3, 2007 08:59 AM
fromme87
1997 - 2003 F150
Jun 9, 2007 09:13 AM
Cracker289
Electrical Systems/Wiring
Dec 29, 2004 01:04 PM
