leaking from vent hose
Old Feb 24, 2007 | 10:37 PM
clunker86's Avatar
clunker86
i have a 1986 f250 with a 400 c6 1345 bg tranfer case. just recently i notice i am having alot of spraying coming from the vent tubing on the transfer case. this is getting all over my floor inside. does anyone know what my problem is and what steps i can follow to fix it. thank you.
Old Feb 24, 2007 | 11:11 PM
Franklin2's Avatar
Franklin2
Take the upper fill plug out, and see if fluid comes out. It may be overfilled. It should be level with the bottom of the fill hole.
Old Feb 25, 2007 | 08:14 AM
clunker86's Avatar
clunker86
ok i know when i had a bad rear out put seal on the transfer it leaked fluid real bad and took it from the transmission, i replaced the seal and filled the tranny back up to specs, but i will check that out. thanks
Old Feb 26, 2007 | 12:54 PM
hoxiii's Avatar
hoxiii
make sure your case isn't all full of water, that'll make it seem overfull and spray out the vent.
Justin
Old Feb 27, 2007 | 06:33 PM
clunker86's Avatar
clunker86
i checked my tranfer case and its full past the fill plug, but what im not under standing right now is why is my fluid from the transmission keep going into my transfer case and causeing it to have too mauch and not enogh in the transmission. what is causing this. thank you
Old Feb 27, 2007 | 06:55 PM
Franklin2's Avatar
Franklin2
I would suspect there is a bad seal between the tranny and the transfer case, but I have never had them apart before.
captradiator
1978 - 1996 Big Bronco
Nov 26, 2010 06:24 AM
imlowr2
Sep 25, 2008 10:15 PM
clunker86
Feb 27, 2007 06:35 PM
dangrimsley
1997 - 2003 F150
Nov 8, 2003 08:25 PM
