1978 - 1996 Big Bronco
85 Stuck n Low 4x4
Old Feb 24, 2007 | 08:14 PM
Sarahs85Bronco's Avatar
Sarahs85Bronco
Unhappy 85 Stuck n Low 4x4
Please help... i was playing in the dirt so i shifted it to low and it wont shift back..i can only go 25 mph. He is an 85 5.0 auto 3.2 i think.
Old Feb 24, 2007 | 08:20 PM
madrockwyo's Avatar
madrockwyo
if it has manual hubs, you might be in luck for an easy solution. just unlock one or both hubs (if possible, hubs might also be in a bind and then move forward abd back a short distance at low speeds and it should unbind the shifter to allow you to shift back into 2wd. If both hubs are two tight to turn, try jacking one wheel off the ground and then wiggle the tire and the hub should release. don't ask me how i know this
Old Feb 24, 2007 | 08:49 PM
Sarahs85Bronco
Talking
LOL ok i wont ask but whats a hub look like? and thank you sooo much!!
Old Feb 24, 2007 | 09:22 PM
Nathane's Avatar
Nathane
did you lock the hubs before playing in the dirt?
Look at the frount wheels, and there should be a hub in the center of them, this is off a chebby, but it's all I could in the google search I did (2 sec)
http://www.chuckschevytruckpages.com.../spicerhub.jpg
Same principal as a ford though, there's a peice in the center with an arrow on it, and a peice on the outside with the words lock, and free on it.
Make sure the arrow's pointing to "free"
Then, put the truck in nutral, and it should come out of 4wd...
~Nate
Old Feb 24, 2007 | 09:58 PM
Sarahs85Bronco
Unhappy Well..you want the good or bad?
Ok
Good: i finnaly know what your talking about
Bad: We tried it twice and he doesnt care. Wont even try to shift out. And when he is in his not low 4x mood he is making a lot of noise under the middle of the frount seat. you know like when we try to put him in 2wd
Thank you soo much for trying to help!!! Its you people that hep that makes me love this site!!!
Old Feb 25, 2007 | 12:28 AM
ag30265's Avatar
ag30265
You should be able to put it in neutral,chock the wheels and get under it.look for a 1/2" square recessed in the top of the trans. case, use a half inch drive extension on a half inch rachet or pull bar to manually force it outta gear.Should turn about a half a round to get it out and should have an arrow on it letting you know which way to turn it.
Old Feb 25, 2007 | 03:21 PM
chris josleyn's Avatar
chris josleyn
Try turning the truck off put it in neatrul then try shifting from 4 low to two high
Old Feb 27, 2007 | 02:20 AM
Sarahs85Bronco
Red face
It didnt work . So ~sigh~ This other bronco guy is gonna take him for a test drive on friday maybe he can figure him out. Thank you soo much for the time you put into helping me!!
Old Feb 27, 2007 | 08:19 AM
Conanski's Avatar
Conanski
The truck has to be in neutral and stopped to shift between 4low and 4hi.. just in case you are trying to do this on the fly.
Old Feb 27, 2007 | 04:09 PM
Sarahs85Bronco
WEll
It was off in nutral..does it have to be off?
