An AOD Question
Old Feb 24, 2007 | 06:45 PM
Campbell 56's Avatar
Campbell 56
Question An AOD Question
OK, I screwed up and lost my old Bronco manual and the separate instructions for turning the shift lever arm on my AOD. It currently is pointing down and I need to turn it up. I'd really appreciate a bit of help, not with my memory, with the shift lever turning.
Thanks!
Craig in Campbell
Old Feb 25, 2007 | 07:13 AM
stuart1's Avatar
stuart1
Remove the valve body.
Undo the large nut inside at the arm.
Remove the small roll pin in the case.
Pull the arm out and crank it around.
You may be able to turn it by just undoing the nut and pushing the rooster comb off.
Old Feb 25, 2007 | 08:26 PM
Campbell 56
Thanks Stuart! I just got it all buttoned back up. I did manage to pop a spring of that keeps pressure on the kickdown valve and lever, but after a few minutes figured out where it goes and had it back in place, no sweat.
That's what I like about this site. Lots of help when I need it!
C in C
Campbell 56
Apr 7, 2010 07:21 PM
Campbell 56
N. California Chapter
Feb 25, 2007 11:58 AM
Campbell 56
Jun 5, 2005 03:07 PM
Campbell 56
Apr 7, 2005 08:35 AM
Campbell 56
20
Sep 11, 2003 08:00 PM
