mileage counter
Old Feb 24, 2007 | 08:57 AM
Joe-F150's Avatar
Joe-F150
Question mileage counter
i have a 2005 F150 supercrew, the digital reading of the odometer went out, its completely blank with no numbers on it, any suggestions?
Old Feb 24, 2007 | 09:18 PM
INFLUENCER's Avatar
INFLUENCER
Buy one off E-bay with less miles and put it in?
Old Feb 24, 2007 | 10:31 PM
Joe-F150's Avatar
Joe-F150
Seriously guys has anyone had this happen and how was it fixed.
Old Feb 24, 2007 | 10:49 PM
Red Star's Avatar
Red Star
Its still under warranty. Take it to Ford dealer.
Old Feb 24, 2007 | 10:52 PM
FTE Trigger's Avatar
FTE Trigger
It seems odd to go out so early.
One thing I'd do is.. get a manual and look at fuses and relays for the display/instrument cluster ( I can't remember if there is one for the display).
Then I'd pop that cluster apart and look at the connections to make sure they're all connected firmly.
Have you gotten your dealer(s) word on what options they could give?
Old Feb 24, 2007 | 11:58 PM
Dunk's Avatar
Dunk
One thing I'd do is...get a manual and.. look at fuses and relays for the display/instrument cluster ( I can't remember if there is one for the display).
Trigger is probably right. There's fuses in them for eveything. There's even a separate fuse for each pin in the trailer plug.
Old Feb 25, 2007 | 02:23 AM
tdister's Avatar
tdister
The one on my '99 goes out a couple times a year. I smack the top of the dash pretty hard and it comes back to life.
If it's under warranty, take it in. You don't want to chance breaking something and having them wonder if you've been tampering with it for one reason or another. If not, let me know and I'll dig up the fix for the '97-03's that had the same problem.
Is that the only thing out? I would have a hard time believeing there is a seperate fuse for that little display.
Old Feb 25, 2007 | 12:38 PM
wrobo23's Avatar
wrobo23
This is a very common issue, one that has a whole topic somewhere here at FTE. There was an issue with one of the pins not having enough/improper solder. Either tap your dash every now and then, take it in to have it checked out, or, like me, live with it. One of those little quirks that make my truck "special"... lol
ilamir
Oct 28, 2011 12:07 PM
FarmyardF150
Jul 23, 2009 12:40 AM
TJ530
New Member Introductions
Aug 25, 2007 01:18 PM
F150 lover
2004 - 2008 F150
Dec 28, 2003 08:58 PM
Custom Junk
Aug 1, 2002 07:43 PM
