4.0L OHV timing
Old Feb 23, 2007 | 11:18 PM
davepiper's Avatar
davepiper
4.0L OHV timing
Is the 4.0L OHV (8th digit VIN=X) engine an interference engine? i.e. If the timing chain breaks, will the piston hit the valves?
Thanks in advance, David
Old Feb 25, 2007 | 11:36 AM
aquanaut20's Avatar
aquanaut20
Never heard of an X engine losing or skipping a timing chain, why are you worried?
Old Feb 25, 2007 | 11:50 AM
RangerPilot's Avatar
RangerPilot
According to my chart, no, it's not an interference engine.
But I'm with aquanaut, I've never heard of a 4.0L blowing a chain.
Old Feb 25, 2007 | 12:17 PM
davepiper's Avatar
davepiper
Never!? That might disappoint me. I just bought a 99 explorer. PO said it was running fine, then wouldn't start one cold morning, he took it to a mechanic, mechanic said he checked for compression on two cylinders & there was none. I was hoping to find broken or jumped timing chain, so I bought it cheap. Trailered it home , but haven't looked at it yet
David
Old Feb 25, 2007 | 03:10 PM
aquanaut20's Avatar
aquanaut20
Are these dead cylinnders ajacent?
I would be more inclined to thing blown head gasket, which are common
Old Feb 25, 2007 | 05:33 PM
davepiper's Avatar
davepiper
I'm not sure if cylinders are adjacent, I just thought it sounded more like a timing chain since it was running good, then wouldn't start. I guess I'll find out more when I tear into it. Might have to wait for some warmer weather though. Maybe head gasket will be an easier fix than timing chain!?
Thanks, David
Old Feb 26, 2007 | 09:18 PM
kevin74656's Avatar
kevin74656
Timing belts, such as those found on most (if not all) OHC engines, require periodic replacement. These belts are made of flexible material, such as neoprene, and will eventually stretch and break if not replaced at regular intervals (usually something like 60,000 miles).
Timing chains, on the other hand, are made of metal, and should last for the life of the engine. I don't think that I've ever heard of one breaking, either.
Good luck - hope that you get it running when the weather warms up!
BTclassics
1983 - 2012 Ranger & B-Series
Mar 3, 2017 07:19 PM
jle70
Jul 28, 2015 07:33 PM
Titantis
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 15, 2007 08:39 AM
BBF250
Jan 9, 2007 02:45 PM
GarySS
Jun 22, 2004 06:21 PM
