Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Afternoon
Old Feb 25, 2007 | 11:28 PM
51dueller's Avatar
51dueller
Yep, the upper and lower intake was all complete with injectors, fuel rail, throttle body, EGR etc. I got this all from Kelly's Mustang Parts. He got all the parts ready in a couple hours and I just had to come pick them up. I later got fuel line, throttle cable and tranny cable, MAP sensor and inertia sensor from Bucks for like $25. All I need is 2 oxygen sensors and a fuel pump then I should have everything I need.
Old Feb 25, 2007 | 11:45 PM
Fomoko1's Avatar
Fomoko1
Originally Posted by 51dueller
Yep, the upper and lower intake was all complete with injectors, fuel rail, throttle body, EGR etc. I later got fuel line, throttle cable and tranny cable, MAP sensor and inertia sensor from Bucks for like $25. All I need is 2 oxygen sensors and a fuel pump then I should have everything I need.
Where did you get the engine and what was the cost?
What was the cost of the upper and lower intake was all complete with injectors, fuel rail, throttle body, EGR etc?
What fuel tank & year are you using, Mustang?
Alot of questions I kow but I need to find out what the cost is, I may go that way yet.
Old Feb 26, 2007 | 08:46 AM
51dueller's Avatar
51dueller
Engine - 84 Mustang HO CFI (came with 2 barrel and duraspark dizzy) - $550
Upper and Lower intake (complete), dizzy, harness and SD 5spd computer - $250
MISC efi parts (MAP sensor, throttle cable, fuel line, inertia sensor) - $30
Going to use the stock tank, I just need to put a return line in the filler tube and since it drains out the bottom, I can just use a high pressure pump.
I still need the fuel pump, oxygen sensors and I plan on replacing the IAC and EAC sensors. If you want cruise, you will need a VSS too plus the vacuum solenoid assemble and booster from the donor vehicle.
The labour intensive part is the wiring harness. It isn't really hard but you have to know how the system works. I could make you a custom harness (from an original. Would just need the connectors) but don't know what wiring supplys would cost (wiring, relays, connector inserts, fuseable link) plus labour. You could buy an aftermarket harness but that's like $900-1000.
Old Feb 26, 2007 | 12:11 PM
preppypyro's Avatar
preppypyro
Sounds like abit of work there. You got me thinking of a 87 bronco i know of that ahs a carb on it, maybe getting that and switching it to efi...
IB Tim
Florida Chapter
148
Jul 29, 2011 06:28 AM
ron's power stroke
34
May 1, 2010 05:48 AM
fire240
Wyoming Chapter
302
Aug 19, 2008 10:49 AM
RDJ184
Maryland Chapter
306
Aug 13, 2008 01:15 PM
phil6608
Nebraska Chapter
652
Mar 23, 2008 04:50 AM
