Sponsored by: Kumho
Ball Joint Problem??
Old Feb 23, 2007 | 12:23 PM
fitmonkey1219's Avatar
fitmonkey1219
Might be a stupid question, but front tires rattle a bit. At a stand still I can move the tire back and forth (in towards the engine and back). Torqued all lugs, but still moves...ball joints bad?
thanks
Old Feb 25, 2007 | 10:02 AM
ubereal2's Avatar
ubereal2
If you are moving the top of the wheel in and out, you have either a bad upper ball joint, or a bad upper control arm bushing, unless it's twin I-beam suspension.
Have you checked the wheel bearing?
Old Feb 25, 2007 | 02:56 PM
StephenH's Avatar
StephenH
check your tie rod ends. When you move the tire, watch the end and see if there is play in it -- if it is moving side to side.
Old Feb 25, 2007 | 08:09 PM
mbatarga's Avatar
mbatarga
Top to bottom movement is ball joints - either lower, or upper (which might be part of the upper control arm for your vehicle). Just replaced both Driver and Passenger sides top and bottom this weekend on my wifes '01 Expedition. It has 106k miles.
Old Feb 27, 2007 | 07:23 PM
bnb29's Avatar
bnb29
how bout bearing play?
Old Feb 27, 2007 | 10:09 PM
fitmonkey1219
re did the brakes this weekend and the wheel bearings were still in good shape...
Old Mar 1, 2007 | 07:54 PM
bnb29's Avatar
bnb29
If the bearing play is in tolerance, then indeed,the suspension could be suspect. A wheel that moves somewhat easily (without pry bars) straight out from the spindle usually indicates improper bearing adjustment. However a ball joint that's ready to fall out might also move as easily. I see you mentioned a "rattle". Are the brake pads shaking in their mounts? Is the brake hardware absolutely corrcect? Is the caliper funtioning properly?
Old Mar 1, 2007 | 07:57 PM
bnb29's Avatar
bnb29
That last post was misplaced here but I see some of it might apply. Sorry bout that.
Old Mar 4, 2007 | 05:35 PM
117wb 4sp.'s Avatar
117wb 4sp.
did i miss what year and kind of trunk. more that likey a ball joint. is it jacked under the a arm near the wheel?alan
Lil Red Sled
May 26, 2013 12:23 PM
66fdtrucknut
1983 - 2012 Ranger & B-Series
Sep 22, 2012 06:11 PM
fridgeddiesel
Jul 5, 2009 08:02 PM
syannuzzi
Oct 16, 2007 09:54 PM
PhinPhan
Mar 17, 2007 10:05 AM
