differential help
Old Feb 23, 2007 | 08:50 AM
marioc956's Avatar
marioc956
differential help
Has anyone ever changed the axle bearing and is it difficult to put in new ones. And has anyone ever rebuild there limited slip carrier is this something I can do on my own or should I take it to a mechanic the truck is a 1988 f150 2wd 8.8 diff. 31spline I installed a limited slip in it with 8 clutches in it. One more question when I start slowing down to make a stop my truck jerks back and forth is it a bad tranny or ujoints. AOD tranny all gears shift good overdrive works good mount is good dont know what else to check.
