Sponsored by: Real Truck
E350 transmission problem
Old Feb 22, 2007 | 08:10 PM
allenrandle's Avatar
allenrandle
1994 E350 with a E40D transmission. Problem: will not shift from second to drive or overdrive most of the time. However, some of the time it shifts correctly. The yellow light on the gear shifter is on sometime and sometimes it is off. What is the problem?
Need help.
Thanks,
Allen
Old Feb 22, 2007 | 09:34 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hi allen, welcome to FTE.
The E4OD is controlled by a computer. I would start by seeing if there are any error codes stored, then go from there.
Old Feb 23, 2007 | 07:18 PM
allenrandle
Unhappy Reply
aTransmission shop says there is nothing electronically wrong with it, but if nothing is wrong, why would the light be flashing. Tried using scanner; it would go so far and give no information. I have a nemesys scanner, but cannot receive any information out of it. Don't know what to do now. I know for a fact that there has been at least three transmissions; vehicle has 160,000 miles. What would cause a minimum of three transmissions to go bad on this vehicle?
Last edited by allenrandle; Feb 23, 2007 at 07:20 PM. Reason: add more information
jpatt504
Feb 27, 2017 08:37 PM
4.9Inline6e4OD
Jun 18, 2016 01:46 PM
Stephan Acevedo
Dec 11, 2015 12:12 AM
198769ford
Oct 3, 2012 08:16 PM
scottw1
Jan 16, 2009 04:17 AM
