Bronco II Ford Bronco II
brake/steering question.
Old Feb 22, 2007 | 10:28 AM
Aggie05's Avatar
Aggie05
Well got the B2 up and going again, and ive noticed when i apply the brakes the beast pulls kinda hard to the left/driver side. What causes this type of nuisance?
Old Feb 22, 2007 | 10:58 AM
mrshorty's Avatar
mrshorty
Mechanical problem in the brakes, Lockout issues (if 4WD, especially if you have auto hubs), problems with tires (properly inflated?), loose steering/suspension components, any number of things.
Old Feb 22, 2007 | 06:35 PM
kernel-panic's Avatar
kernel-panic
Could be the brakes, could be worn parts in the steering. The most infamous first-to-wear-and-break part on the steering on the BIIs and Rangers is the drag link, which ended up being part of a similar problem on my '86 Ranger. Could be just a "dirty" rotor contributing as well.
Old Feb 22, 2007 | 07:44 PM
my72ford's Avatar
my72ford
you could also have a bad caliper..i had that problem once on a jeep i had years ago..after i replaced it it went away
Old Feb 22, 2007 | 08:46 PM
97Centurion's Avatar
97Centurion
Rub my Belly
My money would be on a bad caliper on the passanger side.
Old Feb 23, 2007 | 01:34 PM
Aggie05's Avatar
Aggie05
allright, well 2 votes on caliper...Whats the easiest way to check a caliper?
BTW it is 4wd but manual hubs.
Old Feb 23, 2007 | 03:10 PM
SShank42's Avatar
SShank42
Don't forget the rubber brake line that attach to the caliper. Inside could be deteriorating cause it to hold pressure on the caliper.
Old Feb 26, 2007 | 02:48 PM
Aggie05's Avatar
Aggie05
Thumbs up
Bump
Old Feb 27, 2007 | 09:24 AM
kernel-panic
Could also be the front wheel bearings. One side on mine is a little too tight, I'm thinking... but it pulls a little most of the time, not just on braking. To test the calipers, jack up the front end and spin the tires by hand. They should turn a few revolutions then stop on their own. If one doesn't, or takes longer, then it may be culprit. You can re-check with a second person and get both tires going (or put it on jack stands) and put it in 4 low (if it's a 4x4 model...) and 1st gear and let it idle and then push on the brake pedal to see if one stops before the other. One of them is either dragging too hard or not working properly at all. Hope this helps.
wvbogger
Jan 31, 2008 01:09 PM
Hiexcur
Dec 13, 2002 09:07 AM
BeeerMan
1997 - 2003 F150
Aug 9, 2002 09:52 AM
dinosaurfan
13
Jun 10, 2001 10:53 PM
