Gear ratio help
Old Feb 22, 2007 | 08:42 AM
boogan1's Avatar
boogan1
Gear ratio help
I have a '77 F250 4x4, I believe the truck was originally an automatic, but is now a 4 spd. I blew up the rear end, I broke the pinion shaft. I am trying to determine what rear end i have and what gear ratio so I can find a replacement. There are 44 teeth on the ring gear and 10 teeth on the pinion. I am not sure if it is a dana 60 or 70 and I can't find any tags on it anywhere. Anyone have pics of these two rear ends they can share? Any help is appreciated. Boog
Old Feb 22, 2007 | 08:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Post the axle code off your VIN plate.
Post the trans code off your VIN plate, also
Old Feb 22, 2007 | 08:51 AM
1975Ford's Avatar
1975Ford
boogan1, welcome to FTE, you choosen on cool site.
The gear ratio is 44 teeth divided by 10 teeth = 4.4 gear ratio.
Never heard of this particular gear ratio. Check for a gear tag on front differential cover, or rear differential cover.
The rear axle tag will look something like this picture https://www.ford-trucks.com/user_gal...=94739&width=0
Old Feb 22, 2007 | 09:07 AM
boogan1's Avatar
boogan1
I am currently 100 miles from where the truck is sitting so can't post the numbers off the vin tags. Sorry. I couldn't find any tags on the rearend anywhere. I removed the rear inspection cover and the pinion gear was layin in the bottom of the housing so I was able to get an accurate count on the teeth on it. I got the ring gear number by reaching as far as I could into the housing, referenced off the center of the spider gear pin and counted half around to the same place on the other side of the pin so basically half the gear, and doubled. If I am off it isn't by one tooth either way, so, 43 teeth or 45 teeth. Boog
Old Feb 22, 2007 | 09:10 AM
NumberDummy
It's most likely a Dana 60 rear axle, the ratio could be 4.10-1.
Old Feb 22, 2007 | 09:23 AM
1975Ford's Avatar
1975Ford
Mark the starting point on teeth with something, then start counting teeth.
Old Feb 22, 2007 | 09:37 AM
NumberDummy
3.54-1; 3.73-1; and 4.10-1 : These are the only ratios available for Dana 60 rear axles from 1973 thru 1979.
Your tooth count is in-correct.
Old Feb 22, 2007 | 09:56 AM
boogan1's Avatar
boogan1
I know the count on the pinion gear is correct at 10, my count on the ring gear should be within one or two teeth. I am guessing it is probably a 4.10, can't get any of the three numbers to come out right with a 10 tooth pinion.
Old Feb 22, 2007 | 11:03 AM
Mil1ion's Avatar
Mil1ion
Yes it is more than likely a 4.10.
Put a small piece of masking tape on the first tooth you count ...then again on the 20th one in case you lose count.
axelgawn
Georgia Chapter
Mar 5, 2016 06:20 AM
Buzz44
Mar 28, 2015 12:34 AM
FastGilla
Apr 21, 2011 09:25 AM
rocdril
Oct 9, 2008 06:54 AM
Dan King
Jul 22, 1999 02:51 PM
