Im hoping someone with the service lit will have a read on the gear ratio on a spicer rear end that I pulled out of a 64 F100. The door tag stamp for the rear gear is A9. I was told that is a 4:56 but I have no way to confirm it. A little help would be appreciated thank you.
Well I guess I could confirm it by pulling the cover off and counting ring and pinion teeth but it would be easier and less messy this way. I still will do that before I just assume it is whatever the door tag says it is.
Thanks Bill and John for the speedy replies. Im pretty sure then that it was a 64 with 65 or 66 doors on it and the tag probably was never changed out. So I guess Im not sure what I have for a ratio in the spicer I yanked out of the hulk. Guess Ill pull the cover and count teeth and see if it has the proper clutch assembly and ring and pinion to denote a limited slip. I will report back when I find out what I really have sitting on my garage floor. Thanks again guys I appreciate the help.
