Sponsored by: Real Truck
Yet Another Tire Question.....
Old Feb 21, 2007 | 09:17 PM
johnnyhasbro's Avatar
johnnyhasbro
I have been searching but can't find the right answer. I have a 2006 F-250 4x4,SC,LB and was curious if a set of 37x12.5 would fit without a lift. Maybe just a leveling kit.
Old Feb 21, 2007 | 09:55 PM
RJB1's Avatar
RJB1
I don't think so. I believe that 35s will rub with a leveling kit...
Old Feb 22, 2007 | 08:59 PM
thor1721's Avatar
thor1721
I have an 07 and i was told that with a stock setup that i could run 33-12.50-17
Old Feb 22, 2007 | 09:05 PM
johnnyhasbro
This is where I get a little confused. The new style f 250/350 stock run a 33 or 35 tire. So if you put a leveling kit and taller rear blocks I don't see why 37/12.5 won't fit. They are only a couple inches taller and I think an inch and a half wider then the stock 35's. I think I am just going to do it and see what happens....
Old Feb 22, 2007 | 09:19 PM
Ace!'s Avatar
Ace!
Please do and let us know. I think an F350 with leveling kit would fit, but will likely rub the control arms just based on the taller tire actually comes into the wheel well/control arm when turned.
Old Feb 22, 2007 | 09:24 PM
thor1721's Avatar
thor1721
stock setup will not take a 37'' tire. with a 2.5" leveling kit I was told I could run 35's
Old Feb 22, 2007 | 09:52 PM
PowerStrokeHD's Avatar
PowerStrokeHD
On '05 and up stock trucks 35/12.5 fits nicely. 37/12.5 will not clear on stock suspension but can be squeezed on if you have the snow plow package (X code springs), but it is tight and will have some rubbing.
Old Feb 22, 2007 | 10:20 PM
Ace!'s Avatar
Ace!
A stock 2005+ will run 35" tires. There are a number of people on the board doing it. I think a 37" will be too close to the front bumper and will rub the control arms even with a leveling kit, but I sure could be wrong.
Old Feb 22, 2007 | 10:22 PM
johnnyhasbro
That dosen't make sense. If the truck is stock and has a stock suspension no snow plow prep or anything and has the stock 35x12.5 and you put a 2.5 level kit up front and taller rear blocks why wouldn't they fit? I understand if you turn and lock the wheels it might rub. And besides that most all tires you buy may say one size but when they are measured thay are slightly smaller. I am looking to buy a set of 37x12.5x18 and they manufacture states the overall diameter of the tire is 36.5. I am going to do a little more searching and see what I come up with. Thanks for the input!!
Old Feb 22, 2007 | 10:24 PM
johnnyhasbro
That post was for powerstrokehd
Old Feb 22, 2007 | 10:30 PM
thor1721's Avatar
thor1721
i might be wrong it seems that alot of people are running 37" good luck let us know how it turns out.
Old Feb 22, 2007 | 10:35 PM
david.brady's Avatar
david.brady
I wouldnt do it without some sort of elevation. I tried 35s though and it looked like pizza cutters. Stock may not be high enough. my $.02
Old Feb 22, 2007 | 10:36 PM
PowerStrokeHD
Well first of all, the biggest tire you can get from the factory is 34.1/11 (actual size) and that tire is a fairly tight squeeze. So going to a 35/12.5 starts to make things real tight, width more so than height becomes the problem. When it comes to a 37/12.5 you really have to watch the bumper clearence especially.
Here are some pics of a guy who did 37/12.5's but he does have X codes.
64408&cat=500&thumb=1
Old Feb 22, 2007 | 10:38 PM
PowerStrokeHD
I have been running 35/12.5R18's on my stock wheels and stock suspension with no problems. Mine has tighter clearences to deal with than '05 UP. I bet that even on mine with X codes and bumper spacers I could run 37's.
goodtobeeme
1997 - 2003 F150
Dec 28, 2010 05:44 PM
joeskeeter
Feb 21, 2008 10:23 AM
gotboostido
Mar 18, 2007 06:43 PM
BIG-BAD-794X4
Offroad & 4x4
25
Feb 11, 2006 08:00 AM
stoab
Sep 10, 2002 01:13 AM
