alright, i put in a brand new heater core two weeks ago, due to my last one leaking. did not have a/c decharged (or whatever it is). it seemed to work fine at first. now the a/c is not cold and the heater is not hot. all that blows out is air that is somewhat warm, but definitley not hot or cold. going to try to recharge it tonight or tomorrow, but not sure thats the problem, any ideas???
the weird part is that it seems the warmer air blows when i have it on cool, and the cooler air blows when i have it on warm... maybe its just a coincidence or bad timing (considering the weather changes more than i change my underwear in new orleans, and i change my underwear at least once a day mind you). if it is the blend door, how am i supposed to fix it? i know where it is and how to get to it, but what do i change/fix/adjust once i get there?? thanks in advance
i had the **** replaced about 8 months ago cuz the old one cracked, checked out the new one and it appears to be fine.. im recharging it today and if that doesn't work, ima go check the blend door and pray thats all it is
