77 instrument cluster
Old Feb 24, 2007 | 10:41 PM
  #31
bigun72's Avatar
bigun72
ok will do ....i gotta get them workin ...drivin down the road at night shinin a flashlight on the speedometer is gettin old lol
Old Feb 24, 2007 | 10:57 PM
  #32
bucks77ford's Avatar
bucks77ford
You could always wear one of those headlamps on your head...But then that would cause some glare on the windshield...... Just Kidding.
Hope you get your lights working.
Old Feb 24, 2007 | 11:59 PM
  #33
Mil1ion's Avatar
Mil1ion
You really need to find out if there is power to that blue/red stripe wire on the connector.
Process of elimination in the circuit.
Bulbs okay ?
Switch turned for bright illumination ?
Power to connector ?
PC not cracked on that circuit ?
Power at Blue/red wire at headlight switch ?
Old Feb 25, 2007 | 09:48 AM
  #34
bigun72's Avatar
bigun72
they shure dont give you know slack when u take the swtich out ....its ruff gettin my big hand in there ....is there a place that it unplugs on under the dash ?
Old Feb 25, 2007 | 10:34 AM
  #35
81-F-150-Explorer's Avatar
81-F-150-Explorer
Leave the headlamp switch connected.
Remove the instrument cluster.
Turn headlamps on to the parking lamp position, the first click, with the headlamp switch turned all the way to the left, just before the dome light turns on, so the ilumination circut will be at full power.
Take a test light put the probe on the blue/red stripe wire terminal, at the cluster connector.
Ground the other end of the test light to ground.
Does the test light "light up"
If it does "light up", then the problem is in the instrument cluster or printed circut.
If it doesn't light up, and your heater control panel is lit up, then there is a problem with the wiring between the cluster connector and the splice "Splice #806" that "Bucks 77 Ford" and I mentioned in our earlier posts.
Tell us if you have power at the Blue/red stripe wire at the cluster connector, then we will go from there.
Old Feb 26, 2007 | 08:45 PM
  #36
bigun72's Avatar
bigun72
I FIANLLY GOT THEM FIXED !!!! ...BUT MY CLUSTER THANG IS ROTTED AND THE BULBS DONT GET A TIGHT CONNETION ...SO WERE GONNA GO TO THE JUNKYARD SOMETIME AND TRY TO FIND A GOOD CLUSTER.
BIG THANKS TO ALL YALL FELLAS ....I PRECIATE IT ALOT ...
Old Feb 26, 2007 | 08:52 PM
  #37
bucks77ford
What actually was your problem? Was it your wire or cluster?
Congrats on getting them fixed.
Old Feb 26, 2007 | 08:53 PM
  #38
bigun72's Avatar
bigun72
the dang stripped out cluster .... we replaced all the bulbs to ...but they was all good anyways ...
Old Feb 27, 2007 | 11:54 AM
  #39
81-F-150-Explorer
If you use the printed circut, and front cluster gauge cover you can use the cluster back out of they following years.
1975-1979 F-series
1978-1979 Bronco.
1975-1986 Econoline Vans.
I recommend getting a cluster back piece out of a 1981 to 1986 Econoline Van. The cluster back plastic is made out of better plastic and will less likely rot in the future.
If you just want to swap clusters, you have to get one for a 1977 only. And it may have the same problem yours has etc...
Blue Oval Truck Parts also sells new cluster backs if you are interested in new. And then there is the classified ads too.
Hope this helps...
Glad you got the problem worked out!
Old Feb 27, 2007 | 12:12 PM
  #40
Mil1ion's Avatar
Mil1ion
Ralph, I need a complete list of the different clusters according to year from 1967 to 1979.
The Hipo parts people want to make an upgraded cluster illumination series for these trucks so they need to know all the wiring vs design changes
There already have cluster sets for Mustangs.
Old Feb 27, 2007 | 12:52 PM
  #41
81-F-150-Explorer
Cool, I'll get right on it.
Old Feb 27, 2007 | 07:11 PM
  #42
RDON's Avatar
RDON
I also had problems with the lights on my 77.Mine was the back of the insturment pannel.It was crumbling and falling apart.
With the help of this form I was able to get the RIGHT one on ebay.I'm by no means A machnic and they walked me through it.
Most of the electral problems with my truck is patch work from previous owner-s.Stay factory and do it right.You wont regret it.This form will find the problem.
Don
They can fix my truck ,But not my spelling
victor9909
May 29, 2015 11:30 PM
eviiltim72
Feb 1, 2014 09:03 PM
FordFinatic157
Oct 5, 2013 09:35 PM
