OBD II Doesn't Work
Old Feb 21, 2007 | 02:44 PM
bradleyj's Avatar
bradleyj
OBD II Doesn't Work
I've got a check engine light on my '02 Powerstroke Excursion, so I went to plug in my code reader and it doesn't work. I tried it on another vehicle and it works fine. I checked the fuse panel. The fuse is good and there is power in the socket. I noticed that the cigarette lighter which is on the same circuit as the OBD II doesn't work either. I examined the wiring harness going to the OBD II connector and I noticed a white wire with a blue stripe hanging loose. The other 8 wires in this harness go to the OBD II connector. It doesn't look like this wire broke off because I don't see any female pins inside the connector that don't have a wire going into them. My Haynes manual doesn't show this wiring. Does anybody know what's going on here? Anyone have wiring diagrams they could email me?
Old Feb 22, 2007 | 12:19 AM
Bluegrass 7's Avatar
Bluegrass 7
Look for a pin 16 at the bottom row last pin on your right.
It should have 12 volts on it.
Lead color is LB/Wht.
No power at the lighter is a problem. Look at the fuse for it. It's the same fuse for the
DTC port.
Sounds like you have two problems at the same time.
Old Feb 22, 2007 | 09:16 AM
projectSHO89's Avatar
projectSHO89
Fix the lighter problem and you'll also fix the OBDII port fault.
Fuse F12 in the underdash box supplies both.
Steve
Old Mar 2, 2011 | 03:23 PM
engine70's Avatar
engine70
bradleyj: Did you ever get to the answer for this problem. The symptoms and hanging wire are exactly what i see in my 2006 F350 powerstroke. I realize this is a different decade but if you or anyone else has a suggestion I would appreciate hearing from you. why is the wire hanging?
Old Mar 2, 2011 | 05:39 PM
bradleyj's Avatar
bradleyj
I don't remember all the details, but I do remember that it wasn't the fuse and I don't think that the loose wire played any part in it. I think I had to splice 12V in from another circuit to get power to the socket.
Old Mar 5, 2011 | 09:32 AM
engine70's Avatar
engine70
Thanks for the reply. I turned out to be the fuse. The cigar lighter had been rewired to another power source so it still worked. I didn't see the blown fuse for the OBD the first time I looked. The hanging wire must be used on some other model but not this one.
ctubutis
Escape & Escape Hybrid
Oct 17, 2016 12:06 PM
mike21105
1983 - 2012 Ranger & B-Series
Sep 8, 2016 02:18 PM
bluestang65
Aug 9, 2011 10:10 PM
cesario6868
Mar 7, 2011 06:40 AM
blueovalinvestments
Modular V8 (4.6L, 5.4L)
Oct 19, 2010 07:06 PM
