Made a mistake, need help...
Old Mar 6, 2011 | 07:28 PM
5xkmw's Avatar
5xkmw
'07 F250 superduty. I was running new wires to the front doors, trying to keep everything going thru the factory connection at the door jamb. I've had success in the past drilling thru the factory plugs in the blank(no pin connection) sections. Must have damaged something this time cause the power mirrors now do not work. Everything else(door locks, windows, keyless) works fine. I can see the back side of the door-side male plug and the drill hole is nowhere close to any wires. The truck side female end is buried behind the emergency brake and is almost impossible to get at. I must have nicked a wire in this side, I just can't tell. Any ideas on how to locate the problem, or where I can get a replacement plug or a decent diagram??
Old Mar 6, 2011 | 08:01 PM
Franklin2's Avatar
Franklin2
Autozone has really good diagrams for the later models, but they only go to 2005 or 2006. You could try plugging in a 2005 and see if the wiring diagrams and fuse layout is close enough to work for your truck.
mikeys97ExpEddieB
Sep 10, 2013 05:03 PM
pzp107
May 23, 2013 08:19 PM
shagwill
Sep 24, 2011 07:19 AM
pinball rescue
Apr 24, 2007 11:34 PM
