E4OD fluid capacity
Old Feb 20, 2007 | 11:22 PM
chewyjackson's Avatar
chewyjackson
E4OD fluid capacity
I just replaced my leaking transmission pan gasket and filter.
Does anyone know the refill capacity for a 1992 E4OD transmission w/o having completely drained the torque convertor.
The book shows 16 quarts, but that's gotta be absolutely dry. I can't find a refill number anywhere.
Worse case senerio I just start guessing, but I need to go out an buy the fluid, and I don't want to short myself or get too much and force another return trip.
Old Feb 21, 2007 | 11:46 AM
tuckerd1's Avatar
tuckerd1
I would guess 8 qts. When I put my B&M deep pan on, it took 11 qts and the pan was to add 3-3.5 qts capacity.
Old Feb 21, 2007 | 05:54 PM
Winger235's Avatar
Winger235
Just shy of 6 quarts. The whole thing drained is around 15.5 15.75 quarts.
Old Feb 21, 2007 | 06:00 PM
Hamberger's Avatar
Hamberger
Yes, about +/-16 quarts if you also drained the torque converter. Might need another quart or two depending on what type of cooler you are using.
Lots of oil.
Key to keeping your E4OD happy is to change the oil lots. Minimum every 30k if you do towing.
Seb...
Old Feb 21, 2007 | 06:08 PM
Winger235's Avatar
Winger235
I agree with Hamberger and if you don't get the biggest cooler you can squeeze in to fit. Get a temp gauge for peace of mind.
Old Feb 21, 2007 | 06:39 PM
Ben-jamin's Avatar
Ben-jamin
if you have the deep pan it's more like 7-1/2
Old Aug 20, 2019 | 09:28 AM
croy772's Avatar
croy772
Hi Everybody,
I know this is an older thread but i have a question. The fluid has never been changed in my 1990 F150 (5.0L/E4OD trans). If i just take off the pan cover and change the filter, how much fluid would i need to add back in. I am sorry if this is a dumb question. i just wanted to be sure. Is it the 6 qts or the 16?
Thank you so much for the help!!!
Chris
Old Aug 20, 2019 | 09:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's about 6 quarts.
1996_5.8
Mar 25, 2017 06:34 PM
strokin83
6.7L Power Stroke Diesel
Sep 12, 2012 08:52 PM
tonyford
Escape & Escape Hybrid
Nov 30, 2010 11:21 AM
danlee
Oct 21, 2009 06:45 AM
Calf_roper_John
17
Jan 8, 2008 01:14 PM
