Differential drain plug ??
Old Feb 20, 2007 | 08:32 PM
zx7rhitch's Avatar
zx7rhitch
I have a 82 f150 with a 9 inch differential and no drain plug.I currently have the 3rd member out is there a kit or some way to add a drain plug?
Old Feb 21, 2007 | 09:24 AM
Franklin2's Avatar
Franklin2
You would probably have to drill a large hole and weld in a bung for a pipe plug.
Old Feb 21, 2007 | 12:31 PM
edgescreambeauty's Avatar
edgescreambeauty
I've never tried this but I've heard that you can remove the bottom stud and replace it with a bolt. Then next time, you just pull the bolt to drain. If it's apart, can't hurt to take a look at.
Old Feb 21, 2007 | 12:52 PM
Franklin2's Avatar
Franklin2
That would be slick if the stud does come out. You might have to round up a copper or plastic washer for the bolt.
Gary F-250
15
Nov 17, 2011 11:50 PM
Ceo4sure1day
Sep 9, 2011 03:23 PM
BMWM1
Dec 11, 2008 10:38 PM
blazemate123
Apr 27, 2008 08:03 PM
tbm3fan
Sep 29, 2007 05:21 AM
