ford 9 inch
Old Feb 20, 2007 | 01:09 PM
51panhead0's Avatar
51panhead0
ford 9 inch
why is the 9 inch i got from a bronco off center at drive line hook up, can i make it work for my 55
Old Feb 20, 2007 | 01:43 PM
irondragon79's Avatar
irondragon79
I'm assuming you have a 1951 F-1?
What year bronco did you get the axle from? if its 1978 or later (fullsize) the axle is going to be about 6 inches too wide to fit properly under your truck. The only way to make the axle you have work would be to have it narrowed ($$$) or to find a 9 inch out of a 1972 or earlier 1/2 ton (f-100) which will be a virtual bolt in and the proper width.
Old Feb 20, 2007 | 02:22 PM
GreatNorthWoods's Avatar
GreatNorthWoods
The pinion being off-center will not hurt anything. The driveshaft U-joints compensate for that.
Old Feb 20, 2007 | 03:28 PM
Randy Jack's Avatar
Randy Jack
What Vern said.
The passenger car version of 9 inch needed the driveshaft to run down the tunnel in the center of the car. To do that, the axles were different lengths, so that the u-joint was centered. Truck rears are equal length axles, which offsets the pumpkin.
Old Feb 20, 2007 | 04:12 PM
51dueller's Avatar
51dueller
The stock 55 rear axle 61.25" hub to hub and the the Bronco rear axle is 65" hub to hub. You could make it fit but you would have to run different wheels front/back.
low54
May 15, 2009 08:40 PM
64STYLE
Aug 17, 2007 08:42 AM
Rizzo66_82
1966 - 1977 Early Broncos
Apr 3, 2007 12:45 PM
triple d
Jul 21, 2006 04:26 PM
factorystock
Jun 27, 2002 02:38 PM
