Sponsored by: Auxito
9.75 rear end
Old Feb 20, 2007 | 07:27 AM
Bobby82490's Avatar
Bobby82490
9.75 rear end
Is the 9.75 ford rear end comparable in strength to the dana 60? If i remember correctly the ford is a 9.75" ring gear with 34 spline axles , and the dana 60 is 9.75" ring gear with 30 or 35 spline axles. But the dana 60 has much more aftermarket parts/accesories available.
Old Feb 20, 2007 | 10:14 PM
Racerguy's Avatar
Racerguy
I really don't have any definite answers to that question but I can say that I haven't seen any blown up 9.75s. I think the most I've seen wrong with one is bad pinion bearings.
A Dana didn't use C-clips to hold the axles in. Those have the potential to cause problems but rarely do. The Dana full float or bolt in axles will be stronger but I wouldn't want to guess how much.
What are you doing with your truck that you're wondering about that?
Old Feb 21, 2007 | 07:25 AM
Bobby82490's Avatar
Bobby82490
I told my friend that my axle in my truck, is about as strong as a dana 60 , but its not nearly as popular as the Dana and the ford is semi-float with c-clips which can make it weaker than a full-float axle. And he didnt believe me.
Old Feb 21, 2007 | 10:43 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The D60 rear axle is actually one of the weaker 3/4-1 ton axles. In fact, most people building an off-road truck will swap out the D60 rear for something stronger (14B, Sterling, D70, D80....)
I was actually going to swap in a Sterling 10.50 into my truck for a big block build...But I think Im going to scrap that idea and go with a mid-'90's truck for the simple bolt-in factor of a 514.
74redone
2004 - 2008 F150
17
Sep 21, 2017 10:08 PM
Welder Guy
1997 - 2003 F150
May 29, 2012 08:23 PM
thecardoc
Feb 4, 2010 10:27 PM
YOMAN
2004 - 2008 F150
Nov 22, 2004 01:24 AM
Broncojohn
Sep 23, 2004 04:09 AM
