Sponsored by: Auxito
97' shifting funny
Old Feb 20, 2007 | 06:45 AM
BTAAA's Avatar
BTAAA
97' shifting funny
97' F150 4.6 156k problem shifting gears lately. Can really notice it shifting funny when rpms low, like when I'm going light on the gas peddle. Problem really noticable with over-drive gear while going through hills of Pennsylvania over weekend. Shifts much smother if I put it to the floor while accelerating. Changed fluid at 100k, checked fluid and it's at correct level. Thanks for any advice.
Old Feb 20, 2007 | 07:30 AM
fourwheelin's Avatar
fourwheelin
I have a 99 4x4, Not exactly sure if its the same thing, but a while back my truck was feeling like it was shifting funny when shifting into OD, while at lower speeds, say around 50 mph, and it would miss a little at this speed, but when i pushed the accelerater a little harder and made it kick out of OD, it would then shift and drive good, I took mine to AAmco to get it put on the machine, for $40. they told me my trans was fine and i had a bad spark plug or wire, so i changed them and it was fine ever since. The wierd thing was i had no check engine light on and i took it to 2 other mchanics and they both thought it was the trans. but there machines wouldnt tell them what the problem was, no codes came up on theres. OH one more note is that my spark plugs and wires were only a few months old at that time, but i changed all of them again just to be sure. hope this helps.
Old Feb 20, 2007 | 08:39 AM
BTAAA's Avatar
BTAAA
Yea, I changed my plugs about 20k ago and wires about 60k ago. Didn't even think that could have anything to do with it. I'll check that, thanks.
Old Feb 21, 2007 | 06:33 PM
ALL4RD's Avatar
ALL4RD
My 97 is just starting to do the same thing. When getting ready to change the fluid and filter I noticed that tranny fluid was around the bell housing. This means the pump is going bad and bleeding off pressure because of the seal leaking. Which makes it feel like it is jerking or hunting for overdrive between 50-60mph when you ease into the speeds but shifts fine if you put the pedal to it.
Checked with local Ford dealer for tranny price only today. A bit over 18 hundred $$ with old tranny for core turn in. Without tranny core to turn in add about $600.00. Not that bad with a 5 year 75k warranty.
Old Feb 22, 2007 | 07:13 AM
BTAAA's Avatar
BTAAA
How much fluid are you loosing. Can you notice it when checking your tranny fluid level?
Old Feb 24, 2007 | 09:09 PM
ALL4RD's Avatar
ALL4RD
It is wet from the front of the bell housing back. I have not noticed a major fluid level drop, but it has just started doing about mid January.
Old Feb 25, 2007 | 12:22 PM
BTAAA's Avatar
BTAAA
yea, dealer called me back and #@*&!!!!!!!! and yep, you guessed it - bad trans. Wants $1800. Traded it in Friday.
Old Feb 25, 2007 | 08:52 PM
ALL4RD's Avatar
ALL4RD
I checked with Advance and they are in the range of 14-1500.00 smackers. It is the weekend so they could not give me any details on the warranty. They also said about 2 weeks for it to come in VS next day with Ford.
I have the deep sump tranny pan installed on my truck so I put two bottles of Lucas transmission fix in to see if it helps for the time being. Can't hurt if I am going to change the trans out in a short time. If it makes any improvement I will let you know.
Old Feb 28, 2007 | 09:53 AM
ALL4RD's Avatar
ALL4RD
After about 50 miles with the Lucas fix put in with fresh fluid, the tranny is acting much better but not perfect. I went ahead and ordered a new tranny with Advance Auto. 4R70W3082 Tranny with Torque converter, 2year/24000 mile warranty was $1432.00. This was a different Advance than the other one I checked with the first time. The parts guy was more knowledgeable and said it would be around 5 days to get here. ($375 core charge) The parts guy pretty much guessed what I was there for as soon as I mentioned the transmission. He told me that 96-97 F150, Expedition and Explorers are starting to show up in numbers with the pumps going bad +- 200k miles. Maybe Ford will take notice and do a recall???? We can only hope.
crappiecrazed
Oct 15, 2011 06:44 AM
twisthappyr6
Apr 23, 2011 03:39 PM
buckeyes8603
Apr 10, 2010 12:17 AM
Boa1277
Nov 12, 2005 11:00 AM
kittyhawk
2004 - 2008 F150
Jan 26, 2004 02:40 PM
