On my 77 351M as it warmes up the oil pressure dropes.It runes on the low side of the normal range.Is this a ok thing.It has about 27000 on the engine and I have always kept the oil changed and run Valaline 10/30. When its cold it's HI.
I think I'm fine but would like an opion. Thanks Don
the factory gauges are more like idiot lights than actual gauges, the only way to tell whats really going on is to put in a mechanical gauge. Most likely your fine though, as long as your not getting any lifter clatter etc.
Look at your oil gauge and see where the needle rests when the power is off. For many years, Ford has used gauges where the needles rest below the last mark. The only complaint I'm aware of concerned the 1964/66 T-Birds.
The needles on the oil gauges of 64-66 Birds rested 1/4 inch below the low mark when power was off, so the gauge never got anywhere close to the middle except when the engine was first started.
Ford solved the problem by using a different sending unit that read higher than normal...in effect: a false reading gauge sender.
C6SZ-9278-A Sender, Oil Gauge
Have a direct reading gauge that reads low? Use the above sender (if you can find one) for piece of mind. It worked for T-Bird owners.
The gages will always read below the last mark when off. That is because LOW oil pressure does not mean ZERO oil pressure. That low mark is probably around 5-10PSI. About the point where the idiot light went ON.
Personally I use a temporary mechanical gage when trouble shooting but I like the stock gage system rather than aftermarket stuff. I also like to hook up an idiot light for a better failure warning. I hook the idiot light to oil as well as temp switches.
There is lots of info on the 351M oiling system in the 335 series engine forum.
Thanks.
A lot of good info.That is what is good about this forum. Not being a machnic I know I will get the answere. Sometimes it's not what you want to hear,But that's the way it goes.
PS Sorry for the two post(gauges) I lost one while writing it. It was GONE,So I posted another.So goes the back to back post.
Don
Thanks.
Don
Don, one other thing you might try is to change to a straight viscosity oil. I like using 30HD in summer (New Mexico) and if I go to colder areas, go to a 20 weight. Multivis has polymers which have no lubrication properties what so ever mixed in the oil trying to "stabilize" the pressure across the temp range. I have found that straight viscosity oil while high when cold gives an over all higher oil pressure when reaching operation tempature.
As always JMHO
Reason: spelling
