Engine Block Codes??
Old Feb 19, 2007 | 07:35 PM
BoltBuster's Avatar
BoltBuster
Anyone have a site or book for this engine block code?
D8AE-6015-ED 15
Old Feb 19, 2007 | 08:03 PM
HemiEater's Avatar
HemiEater
try the first post in this forum
Old Feb 19, 2007 | 09:28 PM
BoltBuster's Avatar
BoltBuster
Unhappy
Been there, done that, no help there...
Old Feb 19, 2007 | 11:03 PM
Conanski's Avatar
Conanski
The casting number only tells you so much. Yours is a '78 casting made for full size Fords.. that's the first 4 characters. The second set of 4 tells you it's an engine block. All the rest of the numbers are rev changes, but I have never seen anythnig that specifies what those were. To figure out if this is a smaller 221-302 block or a 351 block, measure the deck height, 8.2" is a 221-302, 9.48" is a 351. Casting numbers on the crank will also tell you the displacement.
PurelyFord
Feb 26, 2017 08:47 AM
Lando25
Nov 30, 2016 11:47 PM
adam83
41
Aug 20, 2015 12:01 PM
Midnight88
Apr 11, 2008 05:26 PM
w951wxj
Mar 8, 2005 12:51 PM
