Hey,
I need a harness for under the Valve Covers. I have someone to replace them, hopefully this won't be extra$$$$ and labor time. Where can I get one that is the least expensive. Also how much should I pay for one. Thanks for all your help By the way its a 96 F250
Kathy
Contact your local International Dealer and get prices. Then check Powerstrokeshop.com and Direct Ford Parts (site sponsor) (remember to add in shipping) and compare prices. I can get most of my parts cheaper from my local International Dealer than online.
here is ohttp://cgi.ebay.com/ebaymotors/Powerstroke-7-3-Valve-Cover-wiring-harnesses-harness-1p_W0QQcmdZViewItemQQcategoryZ33627QQihZ016QQitemZ 260088370642QQrdZ1QQsspagenameZWDVW#ebayphotohosti ngne for you
You only "NEED" to replace the bad one. It woulkd be a good idea to ohm out the others just to make sure they are 100%. Also check the pins in the VCG (Valve Cover Gasket) and the plugs in the engine wiring harness for burnt, or bent connectors.
Should I go ahead and replace all 4 of the harnesses or just the bad one?
It depends on the condition of the harnesses and/or the mileage on the engine. If you don't mind taking the v-covers off just replace the bad one for now. personally I would just replace everything under the v-covers. My .02
