Front axle spline movement?
Old Feb 19, 2007 | 03:34 PM
Reckless's Avatar
Reckless
2000 F250 7.3L supercab shortbed 4x4:
When I replaced my front hubs recently I noticed at least on one side, I could move around the spindle left/right, up/down stiffly after the auto lock hub was removed. I was just curious if that was normal, or if it meant a seal or somethig had worn? Plus with the wheel removed lookng in behind the brake/hub assembly I could what looked like a weather seal ring floating freely around behind the universal joint going into the axle itself. Is that a bad sign too, or no its normal to have a shred of seal break free like that? If it were bad, wouldn't I see a fluid leak or something?
I've got this weird thing about my auto hubs acting like they want ot partially engage 4x4 while in 2x4 (auto) position. If flip my ESOF switch to 4x4 it goes away until I switch back to 2x4 then moments later it grinds again?
With the ESOF switch in 2x4 is it applying suction or pressure or neutral? How about when switched to 4x4? Just trying to narrow down the culprit.
Old Feb 19, 2007 | 06:45 PM
mech2161's Avatar
mech2161
The stub shaft will have movement with the hub removed. You have a needle bearing on the inside and the hub holds the out side.
The seal your talking about keeps dirt out of the axle tube. There is another seal inside the diff to seal the gear oil. I know there has been a pic posted of that the seal. Maybe someone can find that pic and post it up again.
Nothing is applied when in 4x2. When in 4x4 vacuum is applied to lock the hubs.
Old Feb 20, 2007 | 01:46 PM
Reckless's Avatar
Reckless
Thanks. I saw the other thread with a pic and word it was normal. Now just trying to zero in on this hub noise thing while in 2x4. I've got another post on it titled WEIRD...etc.
Mike Bartlett
Dec 4, 2016 12:15 PM
Capt.Schenk
17
Nov 24, 2016 06:26 AM
DidieX
Oct 6, 2015 11:27 PM
agsmv1
Jun 4, 2015 02:45 PM
