ESOF Problem
Old Oct 9, 2016 | 08:30 AM
Capt.Schenk's Avatar
Capt.Schenk
ESOF Problem
When I position the switch into 4x4 High or 4x4 Low the dash lights do not come on. Also, I have a vacuum leak at both hubs.
I tested the vacuum lines from the ESOF solenoid (or whatever it's called, the box on the fender where the vacuum lines originate) and I don't have any leaks in the lines. I put the Mighty Vac straight to the back of the hubs and I definitely have leaks at both hubs.
So, why am I not getting the light on the dash, and why do I have leaks at the hubs? FWIW, I replaced both wheel hub assemblies in March, and everything worked fine at that time. I'm hoping the yellow o-rings are still good. Is there a chance I lost torque on the four bolts behind the hubs causing a failed seal? Is there a seal on the outside of the hubs that could've failed?
Old Oct 9, 2016 | 08:37 AM
Walleye Hunter's Avatar
Walleye Hunter
Do you have the truck in neutral with the brake pedal depressed while turning the ****? I think park will also work for 4 high but 4 low has to be neutral and brakes on.
Old Oct 9, 2016 | 08:50 AM
bigb56's Avatar
bigb56
I can go into 4 HIGH in any gearshift position at any speed, brake or no brake. 4 LOW only neutral and foot on brake as you stated.
To the OP, there are big yellow o ring seals in the hubs that leak over time. everything has to come apart to change them. Did you check your fuses?
Old Oct 9, 2016 | 09:00 AM
Walleye Hunter
I don't know what I was thinking, you are right, thus ESOF
Capt.Schenk
The yellow o-rings were replaced in March. I realize they fail over time, but I figured it would be odd for both of them to have failed within six months of being replaced, which is why I'm wondering if there's something I can check prior to pulling both hub assemblies. I have not checked fuses yet.
Old Oct 9, 2016 | 09:10 AM
Capt.Schenk
I just checked 19 and 111. Both looked good. I also put the vac gauge at the solenoid, turned on truck, switched to 4x4, and didn't have vacuum. So, I suppose the solenoid is bad.
Old Oct 10, 2016 | 06:24 AM
Capt.Schenk
So, why is my light not coming on? What should I check?
Old Oct 10, 2016 | 06:57 AM
Tugly's Avatar
Tugly
When I first got my truck, I replaced every dash bulb because many were dead. If you had an OBDII tool (link in my signature) you might be able to find out if the 4X4 command is working - I think FORScan will show this.
I, too, want to know why the hub leaks vacuum. My front axles and hubs have all new parts, and the front right developed a vacuum leak. I'm contemplating taking it to the shop, due to lack of time to tinker. But... if I know exactly what to look for, I might take it on.
Old Oct 10, 2016 | 10:04 AM
Capt.Schenk
Well, I left the office to visit a job site and just for the heck of it I turned the switch to 4x4 High and the light came on. Because of the leak at both hubs, it didn't go into 4wd, but at least the light came on.
I'm using a vacation day this Friday so I'm planning to replace the yellow o-rings and the o-rings on the autolockers.
I really want to know why the 4x4 only works sporadically. I'm now assuming it's an electrical issue. Any pointers on where to start looking?
Old Oct 10, 2016 | 12:56 PM
Stewart_H's Avatar
Stewart_H
I had a buddy who had a problem with the switch on the transfer case that kept his rig from going into 4-wheel. Had to manipulate it with his hand while someone else turned the switch in order to get it to work. Might wanna check that.
Stewart
Old Oct 10, 2016 | 12:59 PM
Capt.Schenk
I'll take a look at that.
Old Oct 10, 2016 | 01:03 PM
Stewart_H's Avatar
Stewart_H
Something about it popping out of 4-wheel and back to 2-wheel and that's why he had to lay on the ground trying to get it to stay locked in when I turned the switch. When we got it to work, the light would stay on.
My memory is fuzzy so forgive the lack of details.
Stewart
Old Nov 14, 2016 | 11:09 AM
Capt.Schenk
A month later...I finally got around to replacing the yellow o-rings and the o-rings on the autolockers in hopes of fixing my vacuum leak. On the passenger's side, I have a very small leak which I'm blaming on a very rusty nipple (where the vac line attaches to the knuckle). The driver's side is still leaking like it was pre-fix.
I haven't done this yet, but I'm going to swap the PS and DS autolockers to see if the current DS autolocker is the cause of the leak. I'm assuming the yellow o-ring is the seal on the inner side of the system and the autolocker is the seal on the outer side of the system. Is my assumption correct?
For now, I capped all ESOF-related vacuum lines.
Old Nov 14, 2016 | 03:22 PM
brian42's Avatar
brian42
Veteran: Navy
The OEM auto-locking hubs are not the sturdiest hubs and are not designed to be serviceable (at least according to Ford). If it turns out that one of them is a problem I recommend this before you buy another one:
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
I have done this several times and my original auto-locking hubs lasted 280K before I gave up on tracing vacuum leaks and installed the Dynatrac kit.
Old Nov 14, 2016 | 03:35 PM
cps's Avatar
cps
You are correct. If you put new yellow o-rings in it is doubtful they have failed. Did you use the proper tool to set the vaccum hub? It needs to be set in at the proper distance or your hub will not work. i would assume that when you did the hubs in the spring there was no moisture contamination? Any rust could comprimize the surfaces where the seals are.
You could just put in some manual hubs and be done with it.
