79 2wd radius arm bushing help?
Old Feb 19, 2007 | 12:38 PM
move's Avatar
move
I am trying to replace my radius arm bushings and can't tell which bushings to use. There are two types for a 78 and more for the 79.
My truck is a 79 but I have found on the door a build date of 78. Plus it doesn't help that someone has replaced the bushings before and they are two different types on either side.
Please help point me in the right direction.
The turck is a 1979, 2wd, F150, supercab, short bed that came with the 460 and c6.
Old Feb 19, 2007 | 12:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If your 1979 F150 production date is Before 2/1/1979 it uses:
2-C5TZ-3B203-D .. Radius Bushing-Rear
2-C5TZ-3B203-E .. Radius Bushing-Front
If your production build date is After 2/1/1979 it uses:
2-D9TZ-3B203-A .. Radius Bushing-Rear
2-E0TZ-3B203-A .. Radius Bushing-Front
Therefore, all 1965 thru 1978 (and some 79) F100/150's use the earlier bushings.
Source: 1973/79 Ford Light Truck Parts Catalogue: Section 32, pg 5
This is the exact same parts catalog the Ford Dealers use.
Old Feb 19, 2007 | 01:05 PM
Mil1ion's Avatar
Mil1ion
They come in all sorts of colours.
Get the Ureathane ones.
Old Feb 19, 2007 | 01:08 PM
move's Avatar
move
Thank you! I will have to look when I will have to check the numbers when I get home.
When you say front & rear you mean the bushing infront of the bracket and one behind?
How many metal "washers" should their be on each side? (driverside has two and the passanger side has four)
You don't happen to know of where I can look at a diagram of this assembly do you?
Old Feb 19, 2007 | 01:11 PM
move's Avatar
move
I went to Napa and bought one for an early 79 and one for a 78. The ones for the 78 are blue and the 79 just look like black rubber. I was going to compare and see which fit best. But now that I have this information I am going to check with the Ford part numbers.
Old Feb 19, 2007 | 01:18 PM
NumberDummy
Take Dennis' advice, the Ford ones are crappy, and don't last. (Move: ask the NAPA guy for the early bushings)
Clarifing C5TZ radius arm bushing part numbers.
In the 1980's, Ford changed package quantities on 1000's of parts, and by doing so, changed some of the original part numbers. (DUMB & CONFUSING!!)
So...C5TZ-3B203-C became C5TZ-3B203-E and C5TZ-3B203-B became C5TZ-3B203-D.
Move: Front = Forward / Rear = Aft
Old Feb 19, 2007 | 01:39 PM
Mil1ion's Avatar
Mil1ion
Here you go.
http://www.autozone.com/servlet/UiBr...3d800a9ffa.jsp
Your local parts store will have MOOG parts.
this is the set.
http://info.rockauto.com/Moog/Detail.html?K8295_TOP.jpg
here are some to compare.
http://www.rockauto.com/catalog/x,ca...,parttype,7480
Old Feb 19, 2007 | 01:49 PM
move's Avatar
move
The ones I got for the 78 look like these.
http://198.208.187.182/internet/Part...rtnbr=45G30001
Old Feb 19, 2007 | 01:59 PM
move's Avatar
move
Thank you guys! I am going to try to remember to take pictures before and after to post in this thread. I should be able to get it fiqured out now with your help.
Old Feb 19, 2007 | 02:15 PM
NumberDummy
Originally Posted by move
How many metal "washers" should their be on each side? (driverside has two and the passanger side has four) WRONG! See Below
Ford Dealer .. 1971-79 picture the same.
There's a special retainer in FRONT, and a washer in the REAR per side. That's IT!
2-Washer: 13/16" I.D. by 2 3/8" O.D. x 3/16" thick
2-Retainer: E0TZ-3B186-A (shaped to fit bushing on one side, flat on the other).
Old Feb 19, 2007 | 02:37 PM
51dueller's Avatar
51dueller
Here's a picture:
Old Feb 19, 2007 | 03:43 PM
move's Avatar
move
One last question I forgot to ask!
With the truck on stands and the wheels hanging do I need to have a jack under the radius arm? (Is there any pressure there after I have removed the radius arm nut.)
Old Feb 19, 2007 | 04:10 PM
Mil1ion's Avatar
Mil1ion
There are a couple of threads explaining how to check bushings without removing the springs.
Yes you need to jack up the spring perch and use a come-a-long to pull forward on the radius arm
Old Feb 19, 2007 | 04:26 PM
move's Avatar
move
My radius arm bracket is bolted in. Someone has all ready removed the rivets and replaced them with bolts. I was just wondering if when I unbolt all the bolts if it is going to want to shoot off any direction.
Old Feb 19, 2007 | 11:06 PM
move's Avatar
move
I got them replaced and it did take the pre 1979 bushings.
Here is two before pictures
http://i78.photobucket.com/albums/j9...1/DSCF0392.jpg
http://i78.photobucket.com/albums/j9...1/DSCF0390.jpg
After pictures
http://i78.photobucket.com/albums/j9...1/DSCF0395.jpg
http://i78.photobucket.com/albums/j9...1/DSCF0399.jpg
Thank you for your help! I can now get an alignment done.
HonorableKingCab
Sep 19, 2020 07:09 PM
1944sak
16
Apr 16, 2011 10:34 AM
smokeyb97
37
Apr 16, 2011 10:21 AM
wayneasbell
Jan 14, 2007 07:39 AM
mdmbkr
24
Oct 2, 2005 11:21 AM
