1978 - 1996 Big Bronco
Won't start
Old Oct 31, 2002 | 12:25 AM
hitechcpa's Avatar
hitechcpa
Won't start
Turning the key in my '92 Bronco, 4.9L, 5 speed, produces only a single click. Actually, it worked up to this. Used to be I could just try it again and it would work. No more. Only the click now. Upon recommendation, I replaced the ignition switch. No good.
Is the problem the solenoid on the inside fender or the starter itself? Thanks.
Old Oct 31, 2002 | 12:32 AM
mrwizard's Avatar
mrwizard
Won't start
I'm going to assume you know the battery is O.K. You can try bypassing the starter solenoid with a remote starter switch (or screwdriver) to verify the starter is working, and narrow it down that way. Or, have someone turn the key to "start", and check with a volt-meter to make sure you get 12V on the back side of the solenoid.
Old Oct 31, 2002 | 08:09 AM
broncophilly1's Avatar
broncophilly1
Won't start
try hitting the starter with a hammer
sometimes the brushes inside starter get caught
on a high spot and the hammer will loosen the brushes
if it starts you need a new starter
Old Oct 31, 2002 | 09:12 AM
Ford_Six's Avatar
Ford_Six
Won't start
cmancinelli
Aug 17, 2014 12:13 PM
Cole Neese
Feb 22, 2014 06:27 PM
onedcharette
Nov 8, 2011 10:37 AM
tskinner
Feb 16, 2008 02:28 PM
lostbuckaroo
Jan 6, 2004 11:09 AM
