needed radius arm brackets
Old Feb 18, 2007 | 05:54 PM
funinthemud's Avatar
funinthemud
does anybody have a set for a 73 to 79. or know were i can find new ones.
thanks
jay
Old Feb 18, 2007 | 06:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Are you asking for the brackets that bolt to the frame, that the threaded ends of the radius rods attach to? There's a bushing on either side of the bracket also.
What year and truck series? F100/150, 250, 350?
Old Feb 18, 2007 | 07:26 PM
funinthemud
yes it is the bracket that bolts to the frame. and it would be for a 150
Old Feb 18, 2007 | 07:40 PM
Mil1ion's Avatar
Mil1ion
All I could find was drop brackets.
http://broncograveyard.com/bronco/i-...ar_bracket.htm
Old Feb 18, 2007 | 07:48 PM
funinthemud
yea thats all i can find. these aren't going on a 150. i have put a 72 bronco front axle on my 86 bronco II, and it turns out those year brackets fit my frame and the amount of lift i will be running. the drop brackets they sell will be way too long.
Old Feb 18, 2007 | 08:19 PM
NumberDummy
Radius arm brackets are the same for F100/150 from 1965 thru 1979. Bushings are available from Ford, Brackets? Not sure, but they should be easy to find used.
2-C5TZ-3B177-A Bracket, Radius Arm
2-C5TZ-3B203-D Bushing, Radius Arm-Rear
2-C5TZ-3B203-E Bushing, Radius Arm-Front
Old Feb 18, 2007 | 08:23 PM
funinthemud
thanks guys
Old Feb 19, 2007 | 12:37 AM
Mil1ion's Avatar
Mil1ion
I tried 14 different parts places. with no success.
Looks like a wrecking yard item.
Old Feb 19, 2007 | 07:03 AM
117wb 4sp.'s Avatar
117wb 4sp.
i will ask my brother his freind has a stock pile of ford truck parts. they have done that bronco swap too. alan
Old Feb 19, 2007 | 08:04 AM
pintoches's Avatar
pintoches
i have a set of a 77 f250. If they will work you can have them.
Old Feb 19, 2007 | 08:26 AM
NumberDummy
Radius arm brackets are the same for F100/150 from 1965 thru 1979. In 1973, Ford replaced the earlier number with the 1973 number. Bushings are available from Ford, Brackets? Not sure, but they should be easy to find used.
2-C5TZ-3B177-A Bracket, Radius Arm >>> INCORRECT PART NUMBER
SHOULD BE: C5TZ-3B095-A or D3TZ-3B095-A / Right Side
C5TZ-3B095-B or D3TZ-3B095-B / Left Side
F250/350 radius arm brackets will not work.
Old Feb 19, 2007 | 07:03 PM
117wb 4sp.'s Avatar
117wb 4sp.
<TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD vAlign=top>Todd's Garage
2007 Wadsworth Rd
Barberton, OH 44203
(330) 848-4779
</TD></TR></TBODY></TABLE>
try this guy my brother said he has alot of ford stuff. 8 to5 monday tru friday. alan
Old Feb 19, 2007 | 09:20 PM
117wb 4sp.'s Avatar
117wb 4sp.
hope i didnot break the rules here. is it ok to post parts places that aren,t on the board? my brother said too tell todd that mike sent you alan
Old Feb 20, 2007 | 05:25 PM
funinthemud
thanks, i called him today and he has everything i need. looks like i may be on the road soon.
Old Feb 20, 2007 | 09:32 PM
117wb 4sp.'s Avatar
117wb 4sp.
cool my brother said he has trailers full of all ford truck stuff. alan
