Adding a tachometer
Old Feb 18, 2007 | 12:31 AM
jason867's Avatar
jason867
Adding a tachometer
Hello again everyone.
I have a 1988 Ford Ranger, 2WD 2.0L manual. It's a piece of ****, but it runs.
Anyways, it doesn't come with a tachometer, and I'd really love to have one installed.
What's the easiest, cheapest, best way to get one and install it? What does everyone recommend?
Thanks for your time.
Old Feb 18, 2007 | 08:52 AM
tomtoc's Avatar
tomtoc
just installed my scangauge. http://www.scangauge.com/ love it, tons of features, couldn't be easier to install.
Old Feb 18, 2007 | 09:37 AM
Alan D.'s Avatar
Alan D.
YEa, but that says it's only good for 96 or newer. his is a 92. wrong computer.
Old Feb 18, 2007 | 09:45 AM
wendell borror's Avatar
wendell borror
The last tach I had bought was a sun, it had that 60's look with the black housing and chrome bezzle. I attached ti the steering colum, then had the shop hook it up for 50 bucks. This was on an 89 jeep comanche, not as hard as todays stuff I would imagine.
Old Feb 18, 2007 | 11:49 AM
RangerPilot's Avatar
RangerPilot
Well you gotta run the power wires and the wires for the lightning. That's actually the hardest part. Afterwords you just run a wire from the gauge (typically the green wire) to the tach signal wire on the PCM, which is present whether you have a tach or not.
The gauge will have better descriptions and go more in-depth. Someone with the four banger can tell you where to find the tach wire other than the main bundle.
Old Feb 19, 2007 | 03:03 AM
dart7383's Avatar
dart7383
If you have a wiring diagram and the instructions for whatever tach you buy there shouldn't be any problems. It's a great upgrade, and makes driving more fun in my opinion. Wendell, It's good to see another former Comanche driver on here. They were great trucks, but they are all getting a little old now. The newest one is 15 years old now. Mine was a 1986 2.5 2x4 what was yours? I had some headwork and put in the biggest cam Mopar ever sold done on mine. It ran like a motorcycle, I shifted it a 9000 rpm( I know this because I added a tach). It was still dog slow, but a blast to drive. My ranger is more comfortable, but that old jeep touched my soul. I still miss her every day.
Old Mar 14, 2007 | 06:09 PM
jason867's Avatar
jason867
I got lucky today, I was snooping through my dad's garage, finding all kinds of usefull stuff. And I ran across a aftermarket tachometer! Looks slick too.
It's a super pro, and it has what looks like an "mw" symbol in the bottom...
...if that means anything to anyone...
The problem is I don't have any documentation on it.
It has 4 wires;
black & red (I assume these are for power...)
green & white
I'm guessing the green wire goes to the coil (I think the coil has a spot called "tach")
and the white wire is for back-lighting...
If anyone knows for sure, please let me know.
I can just run the back-lighting wire to a parking lights wire, correct?
Also, is there any calibrating to be done? Or will the tach automatically be accurate (hopefully)
And what rpm should my engine idle at? It's a 88 2.0 4cyl.
And for best mpg I should shift at 3k rpm correct?
Thanks for all your time and patience.
Old Mar 14, 2007 | 06:49 PM
Tiggie's Avatar
Tiggie
Your wiring sounds good. Green to the negative side of the coil, black to ground, red to a switched 12V source, and white to 12V lighting source.
You should get a warm idle between 550 and 800rpm just guessing. The four bangers seem to like to shift between 2700-3000 for the best power/fuel econ/wear and tear mix.
The tach should have a switch for 4, 6, and 8 cylinders on the back. Otherwise, it's a 8 cylinder tach only and you'll probably end up with readings twice what they should be. Thats always pretty fun to have when a non-car savvy person rides with you... "Dude, I always shift at 6K. Watch me take it up to 8K! Haha, Honda thinks it's special with a 9K redline."
Old Mar 15, 2007 | 08:20 PM
jason867's Avatar
jason867
it doesn't have a switch.
it has a screw in the back but i'm pretty sure it's to hold the thing together.
I can't remember for sure at the moment but it goes up to 8k I believe.
Old Mar 16, 2007 | 02:11 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Just an off-beat, but still related question to this thread:
Did any of the 80's Rangers come with a factory tach in the gauge cluster? If so, which ones and does anyone know where to find them?
jason867 - IIRC the manual for my 88' 2.3L says ~800 RPM. When ever I have to check the RPM I have to hook up my diagnostic gauge to this green wire.
Tiggie - Very funny, I'll have you know my Acura/Honda feels VERY special with it's Japanese version 9500 RPM tach swapped in.
Old Mar 16, 2007 | 08:34 PM
Tiggie's Avatar
Tiggie
Yeah, they had them back in the first gen Rangers and BII's. It was an option. I looked at an '88 XLT 2.3L and it had one. Wiring one in is a pain I've heard, it's not plug and play like the later ones. If you've got a 4-banger, it's gotta come from a 4-banger, same for V6's. Best if you have the dash wiring harness from a parts truck available
Old Mar 17, 2007 | 08:28 AM
G2IC_Wraith
That might make sense. I do have one that I picked up a while back that I was told came from a Ranger (or BII) that looked like it would fit just fine. When I went to install it the dash plug on mine looks similar to the hole on the cluster but it's different.
So if anyone like jason867, or me, wanted a factory look it would be a huge PITA to do it? That sucks. I am sure that will be a pain in the butt to find just the dash harness plug. Or is this one of those things that would just be easier to replace the harness under the dash with the one from the donor truck?
Old Mar 17, 2007 | 10:19 AM
Tiggie's Avatar
Tiggie
I've never done it myself, so I can speak first hand. But I beleive it would be easier to just get the dash harness out of a donor truck. It's similar to adding a factory tach to a '67-'68 Mustang, which is a complete PITA. Someone designed the '68-'69 Fairlane right, though. It's a separate harness for the tach and wires up like a regular aftermarket one.
It does suck. Gen I Rangers are my favorite, but not that many had tachs, espeically 2WD models like I want. And a tach is one of my favorite options.
Old Mar 17, 2007 | 10:27 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
I don't remember if the one I am getting has a factory installed tach or not but if it doesn't I will buy an aftermarket tach for it.
BGF100
Oct 15, 2016 09:58 AM
70FE250
21
Jun 11, 2016 12:58 AM
redbison00
1947 and Older Ford Trucks
Aug 15, 2015 09:09 PM
Mustangdude1220
3.8 & 4.2L V6
Jul 17, 2007 07:11 PM
alex crease
Sep 19, 2004 11:52 PM
